Sponsored by: Auxito
EGR fail question
Old Sep 24, 2016 | 07:27 PM
02GrayPowerStroke's Avatar
02GrayPowerStroke
EGR fail question
When an ERG fails does it fail open or fail close? Or both ways.
Old Sep 25, 2016 | 12:58 AM
Bluegrass 7's Avatar
Bluegrass 7
It cannot be stated either way.
It is a system composed of many parts.
There are separate tests for dynamic operating functions and electrical tests along with just plain hardware faults.
Dpfe electrical failure code,
Dpfe connecting hose failure code,
Vacuum regulator valve code,
Vacuum regulator valve electrical failure code.
Failure of connecting hardware can set these failure codes.
A port blockage can cause a failure code.
An EGR valve failure can cause a failure code.
Bottom line is you can't state the failure as open or closed condition.
The failure code is the major indicator of what kind of failure was detected.
You go after that type of operational failure only.
For example a 401 code would not be an electrical failure of the EVR valve even though it's part of the testing because the electrical fault take presidence over allowing a dynamic system test to take place. This failure would stop any further testing
Reason is, without the EVR operational the rest of the test procedure cannot be done.
There is a Hierarchical order to testing.
Put it another over simplified way, you cannot put a floor in place in a new house if there is no foundation under it, to support it.
Good luck.
rickm15752
Apr 7, 2019 09:45 PM
Carl Futch
Feb 18, 2016 04:53 PM
rwdfan
21
Jan 12, 2010 12:26 AM
95F250man
Jun 24, 2004 04:44 PM
funfisher
Mar 9, 2003 11:52 AM
