1989 E-150 5.0 Code 34 EVAP Control System?
Old Apr 7, 2019 | 02:00 PM
rickm15752's Avatar
rickm15752
148K miles on this vehicle, EFI, no a/c. A KOEO test indicates Code 34, and my code reader book indicates "(Trucks ONLY): EVAP control system fault / voltage higher than closed limit (V8 models)" Anyone have any recommendations on what this could be? Vacuum? Electrical? Charcoal canister?
Old Apr 7, 2019 | 06:40 PM
rickm15752's Avatar
rickm15752
Is it possible to have a DTC Code 34 and no Check Engine Light (CEL)? I checked for codes with my scanner and see Code 34 is still present. I removed the EGR valve and the position sensor, tested the EGR valve and it seems to hold a vacuum. I cleaned it with some carb cleaner and reinstalled it. I drove the vehicle and it runs fine, no CEL illuminates, not even a flicker. The CEL works because I see it at startup before it goes out. When I returned from driving it I checked for codes and still see Code 34. The whole reason for my concern was a near engine stall, upon deceleration during city driving, but it did not stall and the engine recovered, so I thought I'd check for codes.
Old Apr 7, 2019 | 09:45 PM
rickm15752's Avatar
rickm15752
FIXED - SOLVED!
Because of my code scanner I narrowed my trouble to the EVAP / EGR system. I could've tested the EGR Valve Sensor that attaches to the top of the EGR Valve with a VOM meter, but I thought it was so inexpensive ($29.17) to just replace the part, which I did. The part from Autozone is a Duralast SU209 EGR Valve Sensor. I installed it, then drove the vehicle about 10 minutes, returned home and hooked up my code scanner. The Code 34 was gone and the pass code (meaning all is fine) 11 came up. Hope this helps anyone else have a similar problem.
johnnyfoodstamp
Oct 2, 2018 07:53 AM
02GrayPowerStroke
1997 - 2003 F150
Sep 25, 2016 12:58 AM
Gunnerboy
Feb 3, 2016 06:31 PM
scrobbie
Jan 27, 2014 07:10 PM
rwdfan
21
Jan 12, 2010 12:26 AM
