Muffler testing
Old Sep 23, 2016 | 11:42 PM
Norma stitz's Avatar
Norma stitz
Muffler testing
Is there a way to test a muffler? Sounds odd I know but I'd like to know that it's fine before continuing with any mods. I know some people run straight pipes but I'd like to keep it hushed as possible.
Old Sep 24, 2016 | 07:15 AM
navistarnut's Avatar
navistarnut
You can always go aftermarket with something that breathes a little better and keep things quiet, but from what I am told the stock mufflers were never a problem spot.
Without a whole mess of sophisticated ways to measure pressures I don't know of a way to test a muffler, short of cutting it apart if you suspect a blockage.
I would be more concerned about the cats.
Old Sep 24, 2016 | 07:27 AM
WatsonR's Avatar
WatsonR
When using a muffler, Magna Flow always showed that they didn't restrict flow and carried a live time warranty.
If I has to choose one, that would be my choice.
Old Sep 24, 2016 | 09:38 AM
Norma stitz
I ditched the cat, which when removed looked visually very clear, however the kid I bought the truck from said that when they removed the cat the truck ran a whole bunch better so he was a bit suspect that the muffler had a restriction. Now, the engine was in poor health so maybe that was more the issue but I'm just trying to eliminate the easy stuff going forward. It says ford on it so I'm assuming it's a stock muf.
Old Sep 24, 2016 | 12:14 PM
WatsonR's Avatar
WatsonR
I run a straight pipe as do most, look elsewhere, it's a motor issue most likely causing you issue, not a muffler.
Old Sep 24, 2016 | 12:19 PM
Norma stitz
So aside from lower egt why run a straight pipe? This truck is fairly noisy even muffled and noise isn't my joy in life.
Old Sep 24, 2016 | 05:28 PM
WatsonR's Avatar
WatsonR
If your looking for performance from muffler, there all about the same.
Old Sep 25, 2016 | 06:02 PM
AGE mechanic's Avatar
AGE mechanic
True, but most of the sound is coming from under the hood. A straight piped 6.0L is really not significantly louder. I run straight piped too. I do have the stock cat on her due to emissions testing, but its hollow.
Major Marvin
28
Jun 1, 2011 09:15 AM
kupiec20
Feb 23, 2009 01:19 AM
jadmt
Exhaust Systems
34
Dec 7, 2008 01:05 PM
scottman70
Sep 2, 2007 10:15 PM
seebeew
Exhaust Systems
Jan 12, 2002 09:53 AM
