1997psd 7.3 f250 won't start unless I pull start it with a truck and Es on clutch
the truck is a 1997 7.3 I have tested the HPOP it makes 600 psi at idle and 3000 when revved up but when you turn it over by key it only makes like 1 to 10 but if you hook it up to a truck and pull it then let the clutch out it fires right up runs great. Could it be the started or somthing in the ignition?
The thread you are responding to is 4 1/2 years old. It might be more helpful if you started your own thread with details of your problem. If your problem is simular to the O.P., your starter could be tired.
New to this site. Mis clicked and somehow my respond ended up on this forum. My bad
The following users liked this post:
mantecans
05-08-2010 07:32 PM
Jackson
01-30-2002 09:25 PM
