Fuel Tank Question
Old Sep 22, 2016 | 11:37 AM
Force74's Avatar
Force74
Fuel Tank Question
I've got a 17 CCSB, 4 X 4 with the 6.7. As I understand it, I should have the 34 gallon tank. I filled it up today and have a question. I was below 1/4 tank with the display telling me I have ~60 miles left before empty and mileage at 14.3. It took a little over 20 gallons. At a glance, the basic math seems off. Do Fords typically build in some type of large "reserve" into the fuel gauges?
Old Sep 22, 2016 | 11:40 AM
seventyseven250's Avatar
seventyseven250
Distance to Empty calculations are usually very conservative. But not sure how many gallons will remain when it hits zero typically. I agree, something seems off. If this happens a few times in a row, it might be worth a trip to the dealer.
Old Sep 22, 2016 | 12:04 PM
Force74's Avatar
Force74
In looking at the new "full" calculation.....it seems right on. Its at something like 485. If I take 14.3 X 34....I get 486.2. Ahhh, its probably nothing, but I'll keep an eye on it. Thanks
Old Sep 22, 2016 | 12:54 PM
Rasalas's Avatar
Rasalas
Distance to mty can be reset on the dealers computer. I would rather have "0" be out of fuel. Not some arbitrary number set in the planning department.
Old Sep 22, 2016 | 01:43 PM
Force74's Avatar
Force74
Good to know. Thank You Rob.
Old Sep 22, 2016 | 01:56 PM
Rasalas's Avatar
Rasalas
It might be something you can set yourself with a bluetooth OBD reader and cell phone app and the Forscan system. I just scratched the surface of the abilities of the system. Rodney has (Karl4Cat) turned me on to the system and could explain much more about it.
Old Sep 22, 2016 | 03:59 PM
Highjumper's Avatar
Highjumper
Funny you mention this. I have fueled up 3 times now, twice when the guage read between 1/4 and 1/8 tank remaining. It took around 22-25 gallons to fill me up. I didn't put too much thought into at the time, but it did strike me as odd since I was expecting nearly 30 gallons. When full, the DTE shows over 520+ miles, which is about right. I guess I will have to pay more attention next time I fuel up.
Old Sep 22, 2016 | 04:21 PM
fordmantpw's Avatar
fordmantpw
If it read 1/4 tank and took 25 gallons, then that's almost spot-on for 34 gallons.
Old Sep 22, 2016 | 04:25 PM
Highjumper's Avatar
Highjumper
I'll have to check again, because I believe it was closer to 1/8 on that fueling, and that the one just below a quarter was 22 gallons. Perhaps I misremember, but the thought did occur to me at the time that it seemed to be a couple of gallons off what I was expecting.
Old Sep 22, 2016 | 05:11 PM
fordmantpw's Avatar
fordmantpw
I conveniently cherry-picked the numbers (fullest tank, most gallons) to make the calculations work out.
Old Sep 22, 2016 | 05:32 PM
Rasty1's Avatar
Rasty1
You have a nice problem to deal with, it means you have your truck.........
Old Sep 22, 2016 | 06:59 PM
Jcothren's Avatar
Jcothren
I have been wondering the same thing. I also filled up 3 or 4 times now and each time my gauge shows between 70-90 miles to empty and it Only took 20-22 gallons to fill up...With a 34 gallon tank it doesn't seem to be adding up.
Old Sep 22, 2016 | 07:16 PM
wb6anp's Avatar
wb6anp
I wonder if they take the Unusable fuel into the calculations, Maybe it is a 34 gallon tank but you use 1 to 2 gallons on unusable fuel. which would make it a 32 gallon tank. We may actually never know till some one actually runs out. And no I am not volunteering to experiment
Old Sep 22, 2016 | 09:52 PM
fordmantpw's Avatar
fordmantpw
Maybe the tanks are bigger in the same way that the axles are more capable.
Old Sep 22, 2016 | 09:54 PM
Force74's Avatar
Force74
Lol!
