Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
ABS mod, or MC? 2008 Escape
Old Sep 22, 2016 | 10:55 AM
radioman13's Avatar
radioman13
OK so this issue first started in July on way back from Florida the brakes started going to the floor. You did have normal braking power, but you had to about stand on them. Took it to mechanic who cleaned and adjusted brakes, after that they seemed to work fine. Fast forward to a month later, I was going over some train tracks with a somewhat heavy load, I braked when going over them, right after that it seemed the brakes went about half way before braking. I took it back to same mechanic who said it's now either the Master Cylinder, or ABS module. I have found so many conflicting posts on this I'm not sure which way to go. I'd really hate to spend $400 on MC, and then it turns out to be ABS. There is also a swooshing noise when you depress brake. Any ideas?
Old Sep 22, 2016 | 11:18 AM
ctubutis's Avatar
ctubutis
The swooshing noise is most likely the power brake booster; did that noise begin at the same time as the pedal going too far down? If so, that's a strong indication of your problem.
If the ABS system is having a problem, the computer's diagnostic system most likely is aware of it; might take the car to a parts store and have them pull the computer codes for you, just to check.
Old Sep 22, 2016 | 11:22 AM
radioman13's Avatar
radioman13
As far as I can remember that noise was not there till the last issue began. I can pump the pedal firm when car is off though.
Old Sep 22, 2016 | 11:42 AM
ctubutis's Avatar
ctubutis
I will bet you that you can pump the pedal firm if you disconnect & plug the vacuum hose leading to the power brake booster and start the engine, I'll bet the pedal behaves the same was as you described above. And if you reconnect the vacuum hose and do the test again (engine running) and the pedal again drops to the floor and the noise returns (which is vacuum escaping from the bladder inside the booster) you've just verified a problem.
Old Sep 22, 2016 | 12:14 PM
radioman13's Avatar
radioman13
I can pump it firm now. Are you saying to pull the vacuum hose to confirm that it's the booster? I was under the impression that the booster would not give a spongy brake just a firm one?
Old Sep 22, 2016 | 01:26 PM
ctubutis's Avatar
ctubutis
Yes, I'm saying to pull the vacuum hose to remove the power assist the booster provides and see if your pedal still goes down too far - which it shouldn't in that vacuum-disconnected configuration.
Old Sep 22, 2016 | 01:44 PM
radioman13's Avatar
radioman13
OK, I took it up to O'rileys they didn't pull any codes off it. I'm not sure the guy knew what he was doing though. I just checked brake fluid and it's at right level, and looks clean. As far as pulling vacuum line what do I need to cover that with? I'm willing to give it a shot, just never done it before.
Also thanks for your help man, I have not been able to find much on this.
Old Sep 22, 2016 | 01:48 PM
ctubutis's Avatar
ctubutis
Put a plug (perhaps a bolt or some other appropriately-sized object to seal off that hose) in the rubber hose you pull off the booster.
Old Sep 22, 2016 | 02:28 PM
radioman13's Avatar
radioman13
OK so after pulling vacuum hose from power booster brake was firm. No swooshing noise either.
Old Sep 22, 2016 | 02:55 PM
ctubutis's Avatar
ctubutis
OK, this is pointing to a failing power brake booster, sounds like perhaps a hole has been worn into the bladder, or perhaps an O-ring that seals the booster against the brake master cylinder.
Read this thread, for example:
https://www.ford-trucks.com/forums/9...ng-brakes.html
Do you have the ability to do your own work? autozone.com has some halfway-decent repair manual information on it (I think you need to create an account to view it but it's free).
BTW I would find a different mechanic if I were you.
Old Sep 22, 2016 | 03:00 PM
radioman13's Avatar
radioman13
I have a guy who can help me, how difficult of a change is it? I definitely won't be bringing it back.
Old Sep 22, 2016 | 04:36 PM
ctubutis's Avatar
ctubutis
It shouldn't be really difficult to replace assuming you've got tools, e.g. sockets & ratchets & extensions. Look on the autozone site for more detailed instructions - or Google it, might even be youtube videos explaining it.
koden
1997 - 2003 F150
Apr 27, 2016 02:43 PM
brokeasajoke
20
Feb 7, 2014 04:37 PM
pop's 4X4
1997 - 2003 F150
Nov 5, 2011 04:12 PM
crazer42
Aug 14, 2010 10:47 PM
