ABS bypass yes or no?
Old Jan 7, 2014 | 04:12 PM
brokeasajoke's Avatar
brokeasajoke
88 f350 trying to.get a firmer pedal. New rear and front brakes rears adjusted new rightside caliper new wheel cyls. 3rd master cylinder. Adjusted shoes multiple times. Bypass or just bleed abs? I do think my vac pump is weak or a leak in booster diaphram i only get 2 pedal pushes before pedal gets hard and takes 4 or 5 sec to build vac back up. Truck stops.just as easy with engine off as it does running just hard pedal off.
Old Jan 8, 2014 | 12:32 PM
Gettysburg150's Avatar
Gettysburg150
Hard pedal when with the engine running means you have little to no assist. Bypassing the ABS will not make the pedal firmer. Also that may make your braking more interesting. I suggest leaving the ABS if its working ok.
If you press the brake pedal do you hear a hissing noise? You might try applying the brake after shutting down the engine so you can hear it. Thats usually an indication of the vacuum boosted failing or already failed.
Old Jan 8, 2014 | 02:02 PM
tjc transport's Avatar
tjc transport
i ain't rite
if you only get 2 applications of the brakes and then the pedal gets rock hard, i bet your vacuum pump is shot.
Old Jan 8, 2014 | 03:39 PM
brokeasajoke
Huh? Im not trying ro fix a hard pedal i want it firmer. It takes me a mile to stop ( lol thats somewhat inflated) realize a bad booster causes a hard pedal just dont think that would cause a very soft and sinking pedal
Old Jan 8, 2014 | 03:44 PM
jas88's Avatar
jas88
Well you could block off the vacuum to your brakes, that would firm it up. :-)
Old Jan 8, 2014 | 04:00 PM
tjc transport
i ain't rite
lack of vacuum will give the same feeling as no brakes, because you will really have to stand on the brakes to get them to work.
i bypassed the ABS on my 88 back when it was still new because it gave me sometime brakes.sometimes they worked, but most of the time they did not.
so i got rid of the ABS. brakes have been great ever since, except for the three times the vacuum pump died.
Old Jan 8, 2014 | 04:11 PM
brokeasajoke
Lol jas. Thats one of those why didnt i think of that moments. Thats awsome i laughed out loud on that one. Vac pump booster and rear abs is all that remains. What should vac be on booster hose? Both may be bad. I do hear squishy noise with engine off.
Old Jan 8, 2014 | 05:17 PM
Forddiesel17's Avatar
Forddiesel17
I think you should have a minimum 20 in of vacuum.
Old Jan 8, 2014 | 06:15 PM
tjc transport
i ain't rite
agreed, you want at least 20 inches vacuum.
the brakes will work somewhat down to 15-16 inches, but they get spotty at those numbers.
Old Jan 8, 2014 | 11:04 PM
IDIDieselJohn's Avatar
IDIDieselJohn
I think hes got the same problem my F350. Pedal is to SOFT and goes to the floor before it starts braking.
If I pump it, it comes up. I bled over the front brakes when I replaced a front caliper (other side was already new), and didn't really help. I won't touch the back for now, as i'm gonna break off the bleeders, and then i'll break the lines to replace the wheel cylinders.
I have heard the ABS box can cause a low soft pedal.
Old Jan 9, 2014 | 11:23 AM
Gettysburg150
I read something wrong, who knows what I was thinking lol
If your RABS is messed up I also heard that could cause a soft pedal. I've seen where guys have taken them apart and cleaned/rebuilt them with success.
Bad wheel cylinders, master cylinders, and the ABS block being messed up could cause a soft pedal.
So you get 2 applications then you have to pump the brakes?
Old Jan 9, 2014 | 12:15 PM
irhunter's Avatar
irhunter
I, too, have heard ABS can cause this. What I know is, it sounds like a MC problem.
Roy
Old Jan 9, 2014 | 04:22 PM
brokeasajoke
3 master cyls all act the same. 2 new ones not remans. Booster or vac pump is bad cause after about 2 pumps pedal gets hard engine running and takes 4 or 5 sec to get vac to make it easy to push again.
Old Jan 9, 2014 | 05:02 PM
tjc transport
i ain't rite
like i said before, that is classic symptoms of vacuum pump failure.
Old Jan 9, 2014 | 06:06 PM
brokeasajoke
I read some where else bad pump or booster would cause squishy pedal IIRC.
