Pulled and replaced fuel pump relay - now won't start
Old 09-21-2016, 08:55 AM
Ford SD's Avatar
Ford SD
Ford SD is offline
A little background first:
Starting in mid-Aug I started to have some running issues with my '89 F250, like stalling at idle. It's progressively gotten worse since and now stalls driving down the road. I can hear the fuel pump run when I turn the key to go to start the truck. It's always started with no issues. Even during this stalling problem. I figured I'd look to see if there was something obviously wrong with the fuel pump relay so I popped that out and decided maybe I'd just change it only to find out it's $20. So I brought it back home and popped it back in. Now the engine keeps cranking but it won't turn over. I can still hear the fuel pump run when I turn the key. Now it smells like it's flooded so I'm going to let it sit for a while. Another piece of the puzzle is that I did end up pulling the relay while the truck was running cuz I wasn't sure which relay wasfor the fuel pump. As soon as I popped it off the truck stalled so I'm pretty sure I pulled the right one. But why will it not re-fire after replacing it?? I included a picture of the relay. I'm not sure if this is the original or not. The truck has 160k on it. I'd like to drive it somewhere to see if I could have any codes read but I can't even start it now😩
Old 09-21-2016, 10:19 AM
Ford SD's Avatar
Ford SD
Ford SD is offline
I let it sit for a while and it fired right up. I let it idle and warm up and was going to drive it up to the auto parts place to see if there were any codes they could read. It idled for about 5 minutes then stalled and won't restart again. My guess is if I let it sit for a while it will restart and then do the same thing again. Any thoughts??
Old 09-21-2016, 10:36 AM
joey2fords's Avatar
joey2fords
joey2fords is offline
visually inspect the wiring to the connector on the underside of that relay.
mine was in bad shape when i bought my '89.
Old 09-21-2016, 11:45 AM
Scndsin's Avatar
Scndsin
Scndsin is online now
Look under there for sure, but if you hear the pump pre-prime at key on consistently, its not the relay.
Pull the spout & see if it cranks & runs.
Old 09-21-2016, 02:02 PM
Ford SD's Avatar
Ford SD
Ford SD is offline
What do u mean "pull the spout"? I ended up having to get it towed this afternoon. I took it up to AutoZone once I finally got it started. I was going to have them read the codes. Which they did. But when I got back in to leave the truck would click one time and not do anything. Before I left my house to go to AutoZone I did have to crank it several times to finally get it started. The AutoZone guy thinks maybe I cooked my starter and it was froze up. I banged on it with a hammer to no avail. It was pretty darn hot after turning the Ky in the AutoZone parking lot several times. So we're the battery terminals. I figure I'd just have it towed and let them figure it out. The one thing I certainly don't understand is electric.
Old 09-21-2016, 05:19 PM
Scndsin's Avatar
Scndsin
I googled spout & this was first image from an 07' post from Bill K.
Originally Posted by subford
The Spout connector (Shorting bar) is on the driver’s side near the hood hinge.The photo is from an F-series but the Spout connector (Shorting bar) should look the same.
This is what you un-plug to set the timing on our style trucks. It takes the computer out of the equation.
Old 09-21-2016, 07:48 PM
Lead Head's Avatar
Lead Head
Lead Head is offline
Does the fuel pump run continuously with the key on?
redbayredneck
27
06-29-2019 07:10 AM
bfc4
20
03-12-2016 05:30 PM
uncle junk
19
07-26-2006 06:54 PM
ksvtwin
1983 - 2012 Ranger & B-Series
03-19-2004 09:52 PM
jeff21876
09-23-2002 12:41 PM
Quick Reply: Pulled and replaced fuel pump relay - now won't start
