idi injection pump
Old Sep 25, 2016 | 06:15 PM
madpogue's Avatar
madpogue
Originally Posted by Cruiseomatic
I've heard of that before but can't remember right now what it is, can you please refresh my memory?
It's a switch on the pedal. Closes as you first move the pedal (similar to a brake light switch). The PCM has to see a sequence of open, then closed, before it will fuel the engine above idle. So even if the rheostat were saying "full throttle", when you take your foot off the pedal, the idle switch opens and the PCM says "sorry, I'm going to idle".
The "open-to-closed" sequence is another failsafe. It's in case you start the engine and for some reason the pedal is stuck down (think final scene of "The Blues Brothers"), the engine won't run to redline.
Old Sep 25, 2016 | 08:10 PM
'89F2urd's Avatar
'89F2urd
Hence...dead pedal.
Old Sep 25, 2016 | 08:14 PM
Cruiseomatic's Avatar
Cruiseomatic
Cool thanks.
Old Sep 25, 2016 | 08:19 PM
madpogue's Avatar
madpogue
Originally Posted by '89F2urd
Hence...dead pedal.
Yup, common symptom of the switch not closing early enough.
zigelbaum
Feb 25, 2013 05:20 PM
Bonanza35
Jul 19, 2012 12:54 AM
a711112a
Aug 28, 2009 09:09 PM
AndysFords
Oct 11, 2006 09:26 AM
Jeff_Tiftick
Jan 16, 2002 12:02 AM
