Flare side tail lights
Old Sep 19, 2016 | 03:23 PM
Jaydoubleyou's Avatar
Jaydoubleyou
So I've got a 78 flare side and the tail lights are the universal style. So when I turn my headlights on my tail lights illuminate using the same circuit as my turn signals. And so if my headlights are on, my rear turn signals don't signal because they're already illuminated. For anyone else that has a flare side, are your rear lights like this?
Old Sep 19, 2016 | 03:44 PM
HoustonDave's Avatar
HoustonDave
Your turn signal lights are probably 1157 dual-filament bulbs. One filament glows when the parking lights or headlights are on, the other filament only glows when it has juice from a) turn signals/hazards front or rear or b) when brakes are applied at the rear. If your rears light up the wrong filaments on headlights, either the bulbs have been installed wrong in the sockets (possible) or someone screwed up wiring the sockets and the b side circuit is wired to the headlights. Check that 1) all the bulbs are correctly installed 2) each socket is correctly wired and the bulb base contacts in the sockets get juice at the right times and c) you may as well clean all your grounds at all four corners because sooner or later you will need to anyway and you're there.
Old Sep 19, 2016 | 03:57 PM
Jaydoubleyou
Hey, HoustonDave thanks for the quick reply. So you're saying that the brake lights and turn signals use the same circuit?
Old Sep 19, 2016 | 04:07 PM
HoustonDave
in the rear, yes (obviously you don't have brake lights to the front.) One bulb, two filaments. Two contacts in the base of the socket, one will be hot when your headlights are on, one when either brakes, turn signals, or hazards are on. Hard to say what the problem is without checking it with a test light. Most of the time, though, the problem is not wiring, it is that grounds, sockets, or bulbs have been allowed to deteriorate. But ya never know till you check.
Old Sep 19, 2016 | 05:15 PM
Jaydoubleyou
No with this particular situation it's definitely a wiring issue. I had installed a universal wiring harness and must have gotten it backwards. But thanks again for the help I really appreciate it. I went to get the inspection done today and of course didn't get it because my lights weren't right. So thanks again.
And as a side note HoustonDave, I work in Houston too.
Old Sep 19, 2016 | 05:22 PM
HoustonDave
I am so sorry.... haven't been out today but was supposed to be 97 or so and humid.
If you put in a new harness my first check would be whether you have the parking light hot wire going to the brake light/turn signal contact in the rear sockets on each side.
Old Sep 19, 2016 | 05:36 PM
Jaydoubleyou
Yea it was extremely humid. Unfortunately I haven't installed air conditioning in my truck yet. So it gets a little miserable. But as long as I'm moving the quarter Windows make a world of difference.
But yea I'm pretty sure that's exactly what I did. I'll take a gander at it tonight after it cools down a little. Matter of fact I think I was confused when I wired it up. And pretty sure you just cleared it up for me. One more reason why these forums are great!
Old Sep 19, 2016 | 07:45 PM
c391d's Avatar
c391d
I opened this thread hoping it was where to buy flareside tail lights. I need a driver side one for my 78 and can't find them any where.
Old Sep 19, 2016 | 09:36 PM
Jaydoubleyou
Yea I mean I haven't been able to buy anything original or what not. But the universal tail lights that I used are the ones you can get at the parts stores, or even Walmart. They have the same bolt pattern to bolt right onto the light bracket for the flareside truck. I think I ordered mine off amazon for pretty cheap. And of course I'm not too worried about it being all original.
Old Sep 19, 2016 | 09:50 PM
Jaydoubleyou
But yea I was able to fix the issue. And with this universal harness the turn signal wires are the same ones used for the brake lights. Which I think it's the same way from the factory. But with these dual filament bulbs one is greatly brighter than the other. And both circuits were energizing like they should, however the running lights were energizing the brighter one and so the brake lights/turn signals were not even noticeable with the headlights on. So I just switched the two wires on each tail light and everything is working as it should. I'll go see able that inspection tomorrow first thing. Thanks again HoustonDave!!
Old Sep 20, 2016 | 08:59 AM
HoustonDave
no prob...if you are on the NW/Spring Cypress end of town and spot a primer black '78 longbed...that's me.
Old Sep 20, 2016 | 09:11 AM
Jonnyuma's Avatar
Jonnyuma
There is/was a local (Portland, OR) Craigslist ad for a Flareside being parted-out by a Vancouver, WA wrecker. He wanted $35 ea on the tail lights...I passed. Not sure how he is on shipping, but it should be easy enough to find out...
I'd post a link but that never works from my phone.
Old Sep 21, 2016 | 08:03 PM
monkey-1's Avatar
monkey-1
If you don't want to go back stock, try some from a 53+ F100. I recently swapped the LED versions and love them.
Old Sep 22, 2016 | 10:21 AM
Jonnyuma's Avatar
Jonnyuma
Those are very cool, monkey...I like little touches like that.
Old Jun 28, 2020 | 01:11 AM
Eduardo Castillo's Avatar
Eduardo Castillo
a friend of mines our purchased a complete bed for another truck ill ask him in the am about them tail lights. were in Texas how about you?
uknunn
Aug 6, 2017 01:09 PM
donmi
Feb 18, 2015 10:32 PM
nateraz1
Dec 11, 2012 10:26 PM
1bad71F100
Jan 23, 2006 03:14 PM
derek_seli
Electrical Systems/Wiring
Jun 14, 2003 04:56 PM
