Turn signal/headlight problem
Old Jul 24, 2005 | 08:00 PM
1bad71F100's Avatar
1bad71F100
Question Turn signal/headlight problem
Aight guys ive got a problem. When I turn on my headlights or parking lights, my turn signals or brake lights will not work. Im thinking that somewhere I have a wire crossed. I removed my turn signal lights from the front and wired in some new lights behind the grill for a clean look, maybe I did something wrong there.
Old Jul 24, 2005 | 08:44 PM
Unimog005's Avatar
Unimog005
If I'm not mistaken, the "parking lights" turn off when the headlights go on....so you may have tapped the wrong wire for your new lights.....I'd check out Ebay for a wiring manual for your truck and have a double check of where everything is going....because you never know what someone else did before you go the truck!
Old Jul 24, 2005 | 09:42 PM
Freightrain's Avatar
Freightrain
On the 70-up their front lights stayed ON with headlights(my 70 did anyway). Pre 69 went off. My '69 and 67 turn off.
There are only two wires going to front bulbs...so actually you don't cross them up or the bulb will light the wrong element. Shouldn't affect anything else. Unless you don't have them grounded properly...but that would affect them lighting...not the rear lights.
Hmmmm?
Did things work right before you changed the front??
Old Jul 24, 2005 | 10:54 PM
1bad71F100's Avatar
1bad71F100
Yeah they did work...its got to be something I did...its wierd, when the lights are turned off, I turn on the turn signal and both of the front ones blink....hmmm....i might just re-wire the front part
Old Jul 25, 2005 | 12:56 AM
WillyB's Avatar
WillyB
With wiring, when things really get crazy, I have always found a grounding problem somewhere in the circuit. You might try clipping a ground wire to the housing of your new lights and see if the problem changes.
Old Jul 25, 2005 | 08:16 AM
Unimog005's Avatar
Unimog005
I had to make ground jumpers for both of my taillight housings...because even though they were screwed to the body, they were not making good ground contact.
Old Jul 25, 2005 | 02:23 PM
Freightrain
Ya, grounds can make a lighting nightmare!!!!
I hook each light separately and try them. This will at least narrow the search down to which side is bad. Maybe??
Old Jul 25, 2005 | 03:06 PM
1bad71F100's Avatar
1bad71F100
I'll try that...I never thought about the ground.....thanks
Old Jan 23, 2006 | 03:14 PM
peter bowd's Avatar
peter bowd
i replaced both my front blinkers, one blinks but doesn't work with the head lights, but the other one does the exact opposite, how can i fix it?
dmarsh2400
Aug 19, 2019 03:23 PM
El Camino Man
Electrical Systems/Wiring
Aug 21, 2012 08:28 PM
fromm
Mar 8, 2009 09:04 AM
dasoundman
1978 - 1996 Big Bronco
Jul 11, 2007 09:07 AM
