Cold start the injectors definitely are not "clicking" the way they should be.
Bought a scan gauge II and checked the FICM voltgage and it never drops below 48V
EOT/ECT never really get past 8/9*
Issue is when I first start driving you can feel a definite miss, but as soon as the truck warms up it runs excellent, no issues starting hot. I did put 15w40 in it but upon some research I drained it and put in 5w40 syn and it definitely helped with the issue but it's still there.
Now, I've never owned an 03 so before I buy rev x and add it to the oil does this seem to be my issue? From everything I've read it does but I wanted some advice from you guys first. Thanks.
One other note the battery's are a little weak in the truck so tomorrow I will have new ones-putting this in as a side note in case it may cause an issue
That's fine, too. I used the Archoil and found it very effective. It took a few years, but eventually I did have to change out the injector.
I used revx for a while and it covered up the problem. Eventually polished the spools. That lasted a few years until 2 of them were bad enough and I replaced those injectors
I'ts a band aid for sure I think, for most anyway.
That said, either one is a good temp fix for those that either don't have the time or the extra scratch at that time.
It's also not a promise it works for everyone. I have read a few posts where either product did diddly squat for the end user.
Just wanted to give an update, put the new batteries in, and the rev x in.
At first the engine started the same got in it to drive it by time I made it to the end of my road I felt a difference, yesterday when it was cold I went the same route and it was missing badly went the same route same spot smooth as silk. I removed the stand pipe under the oil filter and added it there, took it down the highway and the coolant temp wouldn't go past 180*
Doubt it's related but in the process of installing a thermostat as I'm taking a beer break typing this
