injector checks
Old Nov 14, 2006 | 02:04 PM
mhs53's Avatar
mhs53
injector checks
How does one find the bad injector in his 6.0? I have a cold start miss and lost power situation. Been told injector or High pressure problem. Wanting to check out. Help?
Old Nov 14, 2006 | 03:29 PM
BowTieHatr's Avatar
BowTieHatr
there is a new tsb that actually solves this issue permanently. 06-22-03 is a reprogram that will cycle the solenoids on the injectors to basically clean off the spools so the valves wont stick. kinda like a dog shaking itself dry. if this does not solve your issue then you might have other issues but i would definitely try this first. if you are under 36/36 then its free, if not then it will fall under your deductible or maybe even cheaper.
