Stupid Roll Pin
Old Sep 17, 2016 | 07:48 PM
Shadowrider123's Avatar
Shadowrider123
Stupid Roll Pin
I need to remove the shift lever off my 64 steering column.
That roll pin will not budge. Ive hammered on it, drilled it, used a dremal on it, oiled it, all to no avail.
About all Im doing is reaming out the hole in the collar bigger.
That stupid pin has to come out.
I figured that when I took a drill to it, it would loosen up and spin. Nope. The metal heated up pretty hot from the drill bit, that didnt break it free either.
I figured that I could dremal it out, nope, its hardened steel and all Im doing is wearing out dremal bits.
Ive had oil on it for a week now.
I need to inspect the shifter for wear, replace the shift detent plate, TS cam, and figure out why the horn isnt working.
Any suggestions?
Old Sep 17, 2016 | 08:04 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
A/T or M/T?
If M/T .. even though it may look like it, there's no roll pin.
Old Sep 17, 2016 | 10:13 PM
Shadowrider123
Its a 292/AT
Old Sep 19, 2016 | 12:19 PM
knucklecars's Avatar
knucklecars
how did you make out?
Old Sep 19, 2016 | 01:02 PM
TA455HO's Avatar
TA455HO
Lead Gopher
I got mine out some time back in my 1966. Looks same as your 1964 from what I can tell of the MPC. For 1964 at least it is Hardware number
357479-S
The thing that made it tricky for me was the rubber insulator 7246 allows the shift lever to move some and seems to bind the rollpin as you attempt to tap it out.
Old Sep 19, 2016 | 02:29 PM
Shadowrider123
The dremal went kaput. Its about 15 years old so I got my money out of it.
Im going to purchase a new one and a couple new bits and go back at it.
I was able to move the boot out of the way. I suspect the pin was to large and they hammered it in.
Jeff64F100CrewCab
Jun 3, 2018 10:11 PM
HoustonDave
Sep 9, 2016 07:03 PM
saemetric
Aug 16, 2015 07:48 PM
ligito
Dec 9, 2013 10:47 PM
cowboywanabe
Mar 4, 2012 08:56 PM
