My crank procedure after disrupting oil in the rails for any reason: Fire up an OBDII tool and monitor battery volts, RPMs, ICP, IPR and FIPW at a minimum. FIPW top left in the video, ICP top middle, IPR top right, RPM bottom right.
The FIPW will show 0.6 as a sync signal with the PCM until the starting minimums are met, then it will fire the injectors once "everything is a go" in the engine while cranking (minimum 500 PSI ICP). In my case, the delay of the ICP rise is due to the purging of air from the oil rails - and you can see the IPR going nuts to compensate. In my video, the situation is less than ideal, because I allowed the IPR to climb to high and the truck initially overfueled. I have since learned to watch the ICP very carefully, and when I see the ICP start to rapidly climb past 100-150 PSI, I let go of the key. I know from experience that the truck will fire off pretty quickly on the next crank.
Pay little heed to the running FIPW time - stock sticks will read closer to 2.8 ms (2800 microseconds).
If your drive gear bolt for the HPOP didn't reach the proper torque, the gear will spin and not deliver the pressure you need.
As for your codes, I'd clear them and see what comes up fresh.
How do I hook up a laptop like that? What is the drive gear bolt supposed to be torqued to?
Attempted to start it again before pulling batteries, Heard some gurgling(?) noises from the frame, I believe it is the fuel pump? I know that there is fuel getting to the fuel bowl as I can drain it out of the back.
I also found this sensor unplugged, did not cause the engine to start.
You can see my tacky fuel line patch haha, Im planning to replace the lines dont worry its just a temporary fix. Guy at auto zone said that it wouldnt work, I was like gimme some 5/8 fuel hose and some hose clamps. Not a drip from it as of yet.
Just tried to start it again, cleared the codes before doing so, the only code that showed up again was the ebp sensor, which I know is bad. So I guess for the time being I can move on, Im getting ready to take the batteries out and take them in for testing.
The video shows my AE at play, but FORScan with a Bluetooth OBDII adapter (OBDII tools link in my signature) is my common solution now.
As for the HPOP drive bolt torque, 96 ft/lbs - according to the book. Of course... putting that much torque on the bolt will turn the engine long before you get the bolt tight enough to function, so you need counterforce on the flywheel nut (15/16" or 24mm).
How do I do the counter force deal? Is that nut in the tranny case? I actually just bought 2 torque wrenches the other day so Im set for that. Haha maybe I need to start the engine old school with the drive bolt xD
Get someone to help you hold the crank while you torque down the HPOP drive to 96 ft/lbs. Or, put a bar on the wrench and try to leverage it onto something that will not be damaged by force being applied to it, like the ground or frame, etc...
Just got back from testing my batteries, both are fine just need a good charge, both of them were at about 30-35% which is understandable with as much cranking they have been doing. Im starting to suspect the ICP. Still need to check some other things first tho.
EDIT: Just checked the upper reservoir level, that was fine.
Yeah probably coulda figured that out, but am I right about the location? Ive gotta take that little cover off correct?
OK thanks. EDIT: I was referring to the accessing the flywheel nut. . . my bad
Why is the fuel pump mounted on the frame? I thought that was something mounted on or in the tank? Is it possible that is the issue? That video a few posts up had some weird sounds coming from that area. Any chance a bad IPR valve would do it? I have to wait for another vehicle before I can go get another one, but thats something I wouldnt mind trying to eliminate. Plus I hear having one of those on hand is a good idea.
All of our (unless modified) fuel pumps are on the frame under the drivers seat. Sometimes when replacing one thing, you bump or move another just enough to damage it or make it jump off the bridge. It is similar to a domino effect and unless you have air in the system or the torque was too light on the HPOP drive gear, you will need to hook it up to a tester.
Is there a way to bleed the air out if that is the problem? Is that something I can take to a parts store and have them test the pump?
If there is air in the fuel system it will eventually work its way back to the tank via a fuel return line. Do you hear the pump turn on for a few seconds when you turn the key to on, but not start yet? Without a gauge, there really is no way to tell what the fuel pressure is.
