Sponsored by: Real Truck
No spare tire key
Old Sep 15, 2016 | 06:45 PM
bachus's Avatar
bachus
No spare tire key
So I had a blowout on the rear of my 05F250SC on the way home from work. Everything WAS going ok, but I still have the anti theft key on the spare lowering device and no adapter for the jack handle.
How do I drop my spare? Ford says that they are no longer available.
Dan B
Central Ks
Old Sep 15, 2016 | 07:17 PM
str8sixman's Avatar
str8sixman
same issue with mine. I ended up cramming my skinny self up around the top of the spare, twisting and puling off the plastic funnel thing that the lowering rod would go through, and using an extractor made for rounded off bolts (cant remember size) on a long extension to get the key out. once you get that out you can lower it down with jack setup
Old Sep 15, 2016 | 07:52 PM
bachus's Avatar
bachus
Found a Good buddy, Cat mechanic that has a set, going to borrow them and see if I can drop it in the morning.
Another good idea from Ford. To bad they abandoned it.
Dan B.
Central Ks
My truck is sitting in a field drive at the side of the road.
Old Sep 15, 2016 | 08:14 PM
Just Strokin's Avatar
Just Strokin
My 2015 still requires a spare tire "key" to lower it.
Old Sep 15, 2016 | 08:38 PM
bachus's Avatar
bachus
Just Stroking it
If I was you, get rid of the key before you need it. All you need is to misplace it or lose it and you're dead in the water.
Dan B
Central Ks
Old Sep 16, 2016 | 07:17 AM
Wingit929's Avatar
Wingit929
Originally Posted by bachus
Just Stroking it
Dan B
Central Ks
When I bought my 2013 this spring the key was missing. I ended up unbolting the bed and lifting it enough to pop off the lock. When I asked ford they said they couldn't get me a key for my existing lock. But can order me a whole new lock & key but I would have to get the old one off. You would think they could assign a key number to your VIN so you can just get a new key.
Old Sep 16, 2016 | 08:34 AM
speakerfritz's Avatar
speakerfritz
there's a few threads with various tactics to lower the tire and once you lower it...you can remove the lock.
Old Sep 16, 2016 | 10:45 AM
Just Strokin
Just Stroking it
Dan B
Central Ks
Dan, I am the only owner/driver of the truck. I know exactly where the key is located and put it back in that location the few times I have used it. Not worried about it being lost. If there were other drivers, I might consider modifying/removing the key from the spare tire winch assembly.
Plus, I carry a photo of the key code and spare tire lock code on my camera and also an email with this photo in my email account.
Old Sep 16, 2016 | 11:37 AM
D.Yaros's Avatar
D.Yaros
Does the 2002 F250 have a spare tire key? I ask as this truck is "new-to-me" and I do not recall reading anything about such a key in the owner manual. Would not want to find out it needs one, and I do not have it, at a time when it is needed!
Old Sep 16, 2016 | 01:26 PM
agpopp's Avatar
agpopp
From one of my old posts.....
Wen't through this back in July when I bought my CC, LB. The key was gone as well- best advice I found on the web was to take a loooooonnnng extension and add a sacrificial cheapo 9/16" socket (I think if I remember correctly) and slide it down the tube and hammer it onto the lock- lock came right out with the socket
Old Sep 16, 2016 | 01:32 PM
fordman19762003's Avatar
fordman19762003
I just took a flat end screwdriver and popped the lock off the end of the winch. I believe I had to remove the plastic funnel to do it but don't remember having to drop the spare.
Pushdeck1
May 23, 2024 08:47 PM
Piffery1
1997 - 2003 F150
Sep 14, 2013 07:04 AM
PWRSTK2K
15
Oct 13, 2009 11:34 PM
shovelrocker
Jun 27, 2007 03:13 PM
oscar_007
1997 - 2003 F150
Mar 29, 2007 01:48 PM
