302 idler wheel
Old Sep 14, 2016 | 08:52 PM
schoo's Avatar
schoo
302 idler wheel
I don't know if their is a idler wheel made to replace air pump on 1989 302 I need to get one
Hope you guys can answer
Thanks
Old Sep 15, 2016 | 02:28 PM
xlt4wd90's Avatar
xlt4wd90
You should be able to just bypass the pump with a shorter belt:
https://www.ford-trucks.com/forums/9...t-diagram.html
Be aware that those air pumps are fickle. If it's left idle for a long time, it tends to seize up. So if you ever need to use it again, you will have to get a new one.
Old Sep 16, 2016 | 09:28 AM
schoo's Avatar
schoo
You right it froze up allready took it apart cleaned sprayed with PB blaster
Thanks for the info
Old Sep 19, 2016 | 10:31 AM
Glaser67's Avatar
Glaser67
Thanks
For my build I wanted to delete mine as I removed all the emissions anyway, but instead of shelling out for an idler I just lubed it up and left it on; don't have to fiddle with belts and such and its hardly visible from above anyhow.
Just some food for thought...
Old Sep 22, 2016 | 07:48 PM
baddad457's Avatar
baddad457
the same pulley used on the Mustang smog pump bypass also fits the f series accessory setup
Old Sep 22, 2016 | 08:14 PM
schoo's Avatar
schoo
Thanks I'll ck it out
UncleCracker302
19
May 30, 2014 05:44 AM
Godlover
Oct 17, 2012 05:35 PM
Freightrain
Sep 27, 2012 05:20 AM
Saurian
Jan 30, 2005 07:51 PM
MiPockets
Aug 27, 2004 06:00 PM
