302 brackets
Old Oct 14, 2012 | 07:30 PM
Godlover's Avatar
Godlover
302 brackets
I found a 302 with AOD to install in my 65 F100. I want to eliminate the air conditioner and smog pump. The power steering and water pump are a V-belt. Then there are two serpentine belts for the air, alternator and smog pump. Is there an easy way to make this happen?
Old Oct 14, 2012 | 10:34 PM
airharley's Avatar
airharley
Easiest way to remove the accessories you don't want is to convert to an all serpentine drive system from March or Zoop. If V-belts are your flavor, then you may have to change the water pump, timing cover, and drive pulleys from another donor vehicle. I bit the bullet on my drive system from March only because in the long run it was more practical then scouring the yard for acceptable combinations.
Although I have to admit I am not sure if the main belt on your system is the V-Belt or not. That and whether or not it is a 302 and not a 5.0
Old Oct 15, 2012 | 06:28 AM
Godlover's Avatar
Godlover
It is a 5.0. I thought they were the same.
Old Oct 17, 2012 | 06:44 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
302 became 5.0L in 1980.
Old Oct 17, 2012 | 07:32 AM
Godlover's Avatar
Godlover
From what I can tell my block is a 1980 with throttle body carb. I am still looking for an easy bracket solution.
Old Oct 17, 2012 | 08:27 AM
NumberDummy
Same engine supports aka towers, stands, perches:
1969/79 F100 302 / 1975/79 F150 302 / 1977/79 F100/350 351M/400 2WD.
Old Oct 17, 2012 | 02:49 PM
Godlover's Avatar
Godlover
I have all that ready to go. My problem is what to do with pulleys and belts so I can get rid of Air-conditioning compressor and smog pump. I don't want to spend a ton of money to accomplish this.
Old Oct 17, 2012 | 05:35 PM
garbz2's Avatar
garbz2
The combined words accessories, cheap, easy are not in the ford dictionary.
Just about every year and application has a differing set of pulleys and crap to get everything to work.
You can add a later serpentine case cover and reverse pump and use a accessory delete for the AC and Smog pump similar to this.
Dorman Products 34163 Dorman A/C Eliminator Kits
Garbz
armyaviation
44
Mar 8, 2017 10:07 AM
polarspeed
Feb 15, 2013 05:53 PM
vwbill
Feb 21, 2010 03:21 PM
30dodge
Aug 7, 2009 05:38 AM
marks69
Jun 11, 2007 08:40 PM
