302 & Air Pump
Old Jan 30, 2005 | 12:11 AM
Saurian's Avatar
Saurian
302 & Air Pump
I got my exhaust done late november/early december. When the guy did the exhaust, the cat's came off. He then just torched the air tube completely shut. So therefore no flow for the air pump, and I have a clattering that seems to be coming from the air pump. Did I blow my air pump? Also, anybody know how to find out how long of a belt I should get? Can I go to the store and order a belt OTC that is designed to bypass this.
This is on my 94 F150 302 5-speed with AC.
Old Jan 30, 2005 | 08:09 AM
KcinMI's Avatar
KcinMI
On my 85, whoever had it before me just took the belt off, the smog pump had its own belt.
Old Jan 30, 2005 | 09:09 AM
95 F150's Avatar
95 F150
When I had my true dual's put on I went through the same thing with the smog pump. The easiet way to bypass it is right in the parts stores parking lot . Just start with a belt that's about 3" shorter than the stock one and go from there. If it doesn't fit keep swapping them out until you find the one you need. My guess is a belt in the 87"+ range.
Old Jan 30, 2005 | 07:51 PM
dgeist's Avatar
dgeist
Assuming you have a serpentine belt, there's an aftermarket fox-body shop that makes a 302/5.0 smog pully idler replacement. It's about a hundred bucks, but will keep everything else "Stock Size" up front:
http://www.windsorfox.com/images/items/idlsp.htm
Dan
Freightrain
Sep 27, 2012 05:20 AM
87-250
Apr 26, 2011 11:22 PM
trotsky13
28
Nov 29, 2009 07:04 PM
icantdo55
1978 - 1996 Big Bronco
Mar 3, 2007 03:19 PM
powerbardad
New Member Introductions
Jan 21, 2007 03:53 PM
