DONE😡😡😡😡
Old Sep 14, 2016 | 01:43 PM
FUZZYDP's Avatar
FUZZYDP
Thumbs down DONE😡😡😡😡
2015 F-250 SC King Ranch 4X4 6.7
Less than 2 years old with 41,000 mi..
Took to shop after quit running. CEL & exhaust filter overloaded messages.
Dealer calls says fuel system full of rust. $10,000 to replace. They will clean exhaust filter. I don't know if it's just me but I don't think I should have to pay $10,000 in maintenance on a $70,000 truck less than 2 years old. Why didn't Ford design a "filter" system to "filter" trash out or blind off protecting a $10,000 fuel system?? I purchased a new Ford truck every 2 years since 1996 with a couple years in that time only going 1 year. I also purchase my wife a new Ford every 21/2 - 3 years since 1991. Never again!
Old Sep 14, 2016 | 02:00 PM
my_crib_too's Avatar
my_crib_too
If this is fuel contamination, isn't that covered by your auto insurance? Not sure I have all the necessary details though. Did you talk to your insurance company?
bruce...
Old Sep 14, 2016 | 02:45 PM
FUZZYDP's Avatar
FUZZYDP
Yes I filed a claim. My point is shouldn't be happening @ all. If you get contaminated fuel it should be caught be the filters before allowing it to destroy the entire fuel system. How many insurance claims before your cancelled?
Old Sep 14, 2016 | 02:47 PM
Amelio's Avatar
Amelio
did you regularly check your fuel by draining once a month? If so I imagine you would see some discoloration? I try to check mine once a month but sometimes its a few months but every time its nice clean diesel.
Old Sep 14, 2016 | 02:51 PM
FUZZYDP's Avatar
FUZZYDP
Yes I do. Even just had dealer service & replace fuel filters. Bought fuel last Thursday mid morning started acting up that evening. On way dealer next morning died.
Old Sep 14, 2016 | 03:05 PM
Ricohman's Avatar
Ricohman
If you are using an emulsifier additive, it will allow the water to move past the filter.
Old Sep 14, 2016 | 03:07 PM
FUZZYDP's Avatar
FUZZYDP
No water was found in system.
Old Sep 14, 2016 | 03:15 PM
my_crib_too
Do you use an additive of any kind? Brand or name if you do?
bruce...
Old Sep 14, 2016 | 04:21 PM
FUZZYDP's Avatar
FUZZYDP
I use Lucas in every 3rd tank.
Old Sep 14, 2016 | 04:36 PM
FullMetalDiesel's Avatar
FullMetalDiesel
I think that may be the problem then (Lucas).Used the oil additive for gas engines but I wouldn't put anything they make in a diesel. Especially the new diesel fuel additives they have out.
I would use something that has been proven diesel trucks (Power Service, Stanadyne,).
Old Sep 14, 2016 | 06:10 PM
FUZZYDP's Avatar
FUZZYDP
The company I work for has millions of $ worth of heavy equipment. They run Lucas in everything including their diesel UTV's. I do not run the "new" additive. The problem is quite easy to see. When you have a filter system designed to allow rust or any solids to pass through it therefore contaminating the entire system you have a poor designed system. We run John Deere engines off carbon steel fuel tanks. They are fueled from fuel suppliers, fuel tanks from back of pickups & fuel cans. The will & do get trash in them. We change the 2 fuel filter, prime system, circulate n filter tank then put them back to work. Nothing complicated. Total charges $250. Not $10K.
Old Sep 14, 2016 | 06:37 PM
suzuki0702's Avatar
suzuki0702
I think your anger is misplaced..id be blaming the fuel supplier you bought the low quality fuel from. Good luck finding a tier4 diesel to run on diesel with water in it
Old Sep 14, 2016 | 06:39 PM
Big-Foot's Avatar
Big-Foot
Cr@p like this sure makes trading in for a 6.2 and going slower up the hills mighty inviting...
I'd be getting the Ford Service CSR involved on this..
Old Sep 14, 2016 | 06:43 PM
FUZZYDP's Avatar
FUZZYDP
I do have a problem with supplier. They initiated the situation. Doesn't change fact about Fords poorly engineered filter system. I never said a word about any water??? I work in the filtration industry. If my results duplicated Fords I wouldn't have any customers.
Old Sep 14, 2016 | 06:45 PM
FUZZYDP's Avatar
FUZZYDP
Ford is involved & said sure sorry to hear about my problem...
