Just got a 2004 FX4 with 160K. Been going over it to find all the little things that need taking care of.
SO when I open the driver door the check arm/stop allows the door to open so far that the front door edge is hitting the bottom hinge. I already found the part I need but I would like to know how to replace this bugger. Searched the site up and down and no luck.
Making some progress otherwise- the fuel door (broken spring) and FPDM (corrosion) will be here tomorrow.
