check arm/ door stop problem
Old 09-13-2016, 07:34 PM
amazngrace's Avatar
amazngrace
amazngrace is offline
Just got a 2004 FX4 with 160K. Been going over it to find all the little things that need taking care of.
SO when I open the driver door the check arm/stop allows the door to open so far that the front door edge is hitting the bottom hinge. I already found the part I need but I would like to know how to replace this bugger. Searched the site up and down and no luck.
Making some progress otherwise- the fuel door (broken spring) and FPDM (corrosion) will be here tomorrow.
ED
Old 09-14-2016, 01:20 PM
amazngrace's Avatar
amazngrace
Solved!
Check arm comes out pretty easy: two bolts on the door side, two nuts on the body side, pulls right out from the inside up by the E-brake.
ED
octaneforce
08-19-2015 07:54 AM
Hoosh
2009 - 2014 F150
12-12-2012 12:01 PM
tip49
17
04-14-2010 04:47 AM
66f-100
06-07-2008 09:54 PM
jcs1966
01-24-2003 02:34 PM
Quick Reply: check arm/ door stop problem
