Ordered mine today. Bed liner question
Old Sep 13, 2016 | 04:39 PM
Fowlthing's Avatar
Fowlthing
I think I might have the line x put over the top rail. I plan on a roll-n lock bed cover later.
Will it look cheap?
Should I stay with the plastic piece that cover the top of the bed rail?
Seems like it would be last longer etc.
This is a blue jean, lariat with most options... so don't want to mess up
Thoughts?
Old Sep 13, 2016 | 04:41 PM
K A M's Avatar
K A M
If you pull the plastic off there will be a bunch of holes where it clips into.
Old Sep 13, 2016 | 04:43 PM
Jace2016's Avatar
Jace2016
GO LOOK AT ONE THE SHOP HAS ALREADY DONE FIRST! Some guys are good and some not so much. Also, not sure if the 17 MY has holes in the top of the rail under the plastic, might be worth finding out first. Personally I'd go under but have seen it done over and looks good as well.
Old Sep 13, 2016 | 05:25 PM
Rutcutter's Avatar
Rutcutter
Why not order the Ford tough bed liner like I did? I'm very impressed with the quality plus its already done when your truck gets here.
Old Sep 13, 2016 | 05:36 PM
Azuretruck's Avatar
Azuretruck
It's worth considering the factory liner as Rutcutter said. I had liner spray the bed last week. Apparently Ford changed bolts for the bed and line X didn't have the socket so they sprayed over bed bolts. It doesn't look as clean as it would have if they removed the bolts.
Old Sep 13, 2016 | 05:46 PM
EpicCowlick's Avatar
EpicCowlick
AZ, they can fix that for you once they get the proper tools. They can cut the liner off the top of the bolts and remove them as they wanted to in the first place. Then they can spray the exposed bed under the bolts and replace them. There's no need to mask off the bed and it should look like it never happened. It should be easy for them. Line X has a lifetime no-questions-asked satisfaction warranty. This is one of the big advantages of the Line X. The warranty doesn't expire at 3 year 36000 miles.
Old Sep 13, 2016 | 05:54 PM
dlauffenburger's Avatar
dlauffenburger
Will it look cheap?
Thoughts?
Not sure about the roll-n-lock, but my Backflip cover is attached with clamps which seals the frame to the plastic cap on the bed rails. The edges of the bed rails are still visible so the plastic maintains color scheme of the truck. My Backflip has been in place 5 years and still doesn't leak at the rails.
Old Sep 13, 2016 | 06:00 PM
4dogdoc's Avatar
4dogdoc
Personally I would not go over the top of the bed rail w/the spray liner. Even with a straight, even line, I just think it looks cheap. You asked. Just my 2 cents.
Old Sep 13, 2016 | 08:41 PM
Azuretruck's Avatar
Azuretruck
I did not know that. Thank you for telling me. I will definitely check with them in few months
Old Sep 13, 2016 | 08:52 PM
RubyRed350Platinum's Avatar
RubyRed350Platinum
Go Line-X!! My Chevrolet factory spray in liner is cracking and separating fron the bed. It's only a 2015 but Chevrolet won't warranty it as my truck has 70,000+ miles on it.
Old Sep 14, 2016 | 12:46 AM
Jace2016's Avatar
Jace2016
Chevy? Hmmmmm........
Old Sep 14, 2016 | 02:27 AM
Wealthk1's Avatar
Wealthk1
Thumbs up Factory Spray Liner!!!
I have the factory spray liner on my 2013 Platty..... We have banged it, loaded lots of skid loads into it, and thrown stuff in the bed. Not a damn scratch. Could not be happier. (Wish I could say the same for the plastic tailgate cover that house the HUMP for the Step and Hand assist, it has a few rubs on it...LOL)
I have it ordered on my new SD!
Old Sep 14, 2016 | 05:38 AM
Fowlthing's Avatar
Fowlthing
Dealer is a line X dealer as we'll and got it included in the negotiation.
Thanks for help
Old Sep 14, 2016 | 05:45 AM
EightySecond's Avatar
EightySecond
I would have told those Line-X folks "ok, go to the Home Depot, NAPA, Lowes, whatever, I'll wait".
Old Sep 14, 2016 | 07:36 AM
charlesweaver3's Avatar
charlesweaver3
What is everyone paying for a LineX on a 8ft bed? Does the Ford liner really only have a 3yr/36000 warranty?
