Gauges going crazy
Old Sep 13, 2016 | 01:31 PM
Cantfinditgrindit's Avatar
Cantfinditgrindit
Gauges going crazy
So I took my truck for a drive the other day and noticed something funny. My speedo was bouncing, My gas gauge would be near E (I was low on gas anyway) and then would spime to full every 5 seconds or so. Not sure if I have a bad ground or battery or maybe even alternator. Where are all the grounds for the truck anyways? Probably gonna go through and clean them up. Then test the alternator and possibly throw in another battery to see if it rids the problem.
Old Sep 24, 2016 | 11:26 PM
Cruiseomatic's Avatar
Cruiseomatic
I could be wrong, But either 92 or 93 was the last year for cable driven speedo's. If cable driven, Get a new cable. Fuel gauge going full then back empty is a contact problem. At infinite resistance, Gauge reads full. At low, Reads empty. Could have a bad sending unit or loose wire above tank. Alternator has nothing to do with either problem. Ground maybe but I think the ground return for fuel gauge is wired back to cab and doesn't rely on body ground.
But not knowing much, Just going off avatar, You have a 92-96 f-series. Probably a 250. Need more details.
Old Sep 25, 2016 | 12:34 AM
87 XLT's Avatar
87 XLT
Dont know what you're driving or how the speedometer is setup, but is the cruise control working?
Old Sep 25, 2016 | 10:30 AM
subford's Avatar
subford
Sounds like bad wire on the drivers side frame.
An open wire to the fuel sender will peg the gauge and speedometer wiring runs in the same harness.
More than likely rodent damage.
As far as the grounds go:
Old Sep 25, 2016 | 04:47 PM
Cantfinditgrindit
Sorry for not giving more info. It's a 93 f150 with the 5.0 in it. I cleaned the ground near the battery but thathe was it.
Old Sep 25, 2016 | 04:48 PM
Cantfinditgrindit
The gas gauge is what goes up and down... The speedo just jumps up and down a little.
Old Sep 25, 2016 | 05:11 PM
rla2005's Avatar
rla2005
1991...1992 and newer use electronic speed/odometer.
Old Sep 25, 2016 | 05:21 PM
Cruiseomatic
Must be 92 then with the new body style.
Old Sep 25, 2016 | 06:21 PM
rla2005's Avatar
rla2005
Yes indeed, you are correct.
RojoStar
Aerostar
Nov 1, 2025 10:57 AM
Boss9F100
Dec 8, 2018 05:00 AM
1996_5.8
Jul 31, 2018 11:55 AM
Vashon Islander
Sep 14, 2014 05:37 AM
afreemanmd
Electrical Systems/Wiring
Feb 24, 2009 10:43 PM
