Headers
Old Sep 12, 2016 | 06:05 PM
deljac's Avatar
deljac
Headers
I've got a 1996 f150 with the 5.8. I just installed long tube headers. They have o2 bungs but the pass side is facing the trans so it's useless. So I tried wiring up 1 to plug into the ds and PS wiring but it runs like **** then. If I leave them unplugged it runs like a raped ape but idles like crap. I've only ran the front o2 sensors for over 5 years. And it's always ran great. Do I need to weld in a pass side bung and run 2 sensors. What has everyone else done. Thanks in advance
Old Sep 13, 2016 | 08:43 PM
deljac's Avatar
deljac
OK no help. Anyone else with a 96 f150 running headers how did you do it
Old Sep 13, 2016 | 09:38 PM
raystankewitz's Avatar
raystankewitz
I would think if it had two sensors before you added headers, it still needs two sensors. I'm not sure why that passenger side bung is clocked so badly, though.
If your truck is MAF equipped, I"m pretty sure it needs to read both sides of the engine to make it idle correctly.
Old Sep 13, 2016 | 10:02 PM
timbersteel's Avatar
timbersteel
What headers?
I bought Pacesetter header's and had the same problem!
Even with a replacement set, tge O2 bungs weren't correct. I know how you feel.
I got my passenger side O2 in, and just barely. You'll have better luck welding in an O2 bung where you can access it best.
Old Sep 13, 2016 | 10:07 PM
Lead Head's Avatar
Lead Head
Weld a new bung in.
Old Sep 14, 2016 | 02:13 AM
GoinBoarding's Avatar
GoinBoarding
Just for knowledge sake: you can run without the post cat sensor with no running issues, it's just checking the cats but not used in fueling changes. The front two sensors are critical during closed loop operation for correct fueling; so basically the truck will only run ok if in open loop with the front sensors compromised: completely cold (open loop on startup), heavy throttle, and deceleration conditions. You must run both front sensors.
Old Sep 15, 2016 | 06:43 AM
deljac's Avatar
deljac
OK thanks. I kinda figured I'd have to run both
96fonefitty
Exhaust Systems
Dec 28, 2013 12:24 PM
eastcounty_sd
Oct 28, 2004 10:22 AM
lt
Aug 13, 2003 07:47 AM
oldford2
Jun 18, 2003 09:46 PM
KyFord351
Jul 26, 2002 11:35 AM
