Cam Break In
Old Sep 11, 2016 | 07:58 AM
RandyP63's Avatar
RandyP63
Cam Break In
I was hoping someone could help out with this. I just put a new Summit Cam(285/.456 lift) and lifters in my 70 302, I also put in new valve springs from Trick Flow (115.0@1.700, Open 285.0@1.200, 340 rate, coil bind 1.113). My question is, are the valve springs pressure too much for the cam break in period. I have seen some online videos that suggest that the lighter the spring, the better. I just don't want to screw up my new cam. And the last time I installed one was 30 years ago. Would I be okay with this combination? Thanks.
Old Sep 11, 2016 | 08:31 AM
orich's Avatar
orich
In most cases best to use lighter springs for break-in. But what's the differences between the stock springs the new ones.
Second is most importance is using the correct type of oil for flat tappet motors.
And did you change out the push rods or reuse the old ones?
When using old push rods hopefully you rolled them on a flat surface checking for any bent ones. Bent push rods don't turn very good that can cause the lifter not to turn that ends up with cam lobe failure soon after start up.
But you may know all this stuff.
This may not may have answered your question, but as you may get more info down in the Engine forum page.
Orich
Old Sep 11, 2016 | 08:36 AM
RandyP63's Avatar
RandyP63
Thanks for the reply, I checked the pushrods and they looked good. I was not sure what the specs were on the old springs. I live fairly close to all of the race shops and I bought Joe Gibbs break in oil, it's ready to go, I for some unknown reason thought that I would check youtube for extra pointers on break in (since I have not done it in awhile), and now I am second guessing myself.
Old Sep 11, 2016 | 11:20 PM
spdcat72's Avatar
spdcat72
For flat tappets, you need a break in lube with extra zinc. I think it's referred to a ZDDP.
Old Sep 12, 2016 | 06:12 AM
matthewq4b's Avatar
matthewq4b
Yup that is the ticket Fill with a CI-4 rated oil like Rotella triple and add a break in additive such as Comp Cams break in additive. Summit has lots of break in additives available.
RandyP63
Oct 2, 2016 03:08 PM
petes79f150
Jul 9, 2007 05:42 PM
jambroson
Mar 11, 2004 02:51 AM
51truck
Jul 30, 2003 12:03 PM
fordtruckin
Mar 7, 2002 08:38 PM
