I currently have stock rockers, lifters and springs on a 428. The local machine shop is telling me that I need to add new valve springs to use this cam. It is a pretty mild cam.
Yes. Ask them if they tested yours first. The 901 could work with stock springs possibly but it has quite a bit bigger lift. If your springs test out to be close to what is on the spec card then go ahead and use them but they are likely worn and not holding good pressure anymore.
The crane powermax cams have a lot of lift. I would put in new valve springs. Go for the adjustable rocker arms too if you've got the cash, will need new pushrods also. How old is your timing chain, since you've got it tore apart its a good time to put in a fresh chain and gears.
