4.6 into F100 wiring questions.
I am sure this has been covered but i havent had luck searching and 5 pages back i gave up.
I have a 79 F100. CV front end obviously.
Doner engine, trans and harness is from a 93 grand marquis. I pulled the entire engine and chassis harness minus the rear doors.
I have the fuel pump harness and inertia switch, ecu and so on.
As far as getting the truck running, what do i need to hook up and install other than the obvious grounds.
I have the column and cluster that i can use. I pulled every wire from the car that I could find.
Are there any specific sensors that I would need to make sure are wired in before it will fire? Does the ecu need to be mounted and grounded?
I have done swaps before but never a bare minimal car to a fuel injected car with a computer.
I will take any info that you can give me or even a thread or two about someone who has done it before.
Tony79f100
09-16-2016 10:11 PM
old_blue1
11-19-2014 09:20 PM
bigwindow56
02-05-2007 12:12 PM
