O2 sensors going bad.
About a month or so ago I had to replace one of the O2 sensors on my truck. Just last night my "check engine" light comes on. I had it tested at Autozone and it turns out another sensor is going bad. Slow response on the one located behind the cat converter. I guess my question is do these go bad this quickly? My truck only has 46,000 miles on it.
Originally posted by Rockledge
What was the number of the code that came up? I'm guessing that it was P1137 or P1138 in which case the Ford Manual says the following (also applies to codes P1157 and P1158):
I don't remember what code was pulled. It came back something like "bank 2 sensor...." and something after that about slow response.
Bank 2 is the driver's side....and if it's located behind the Cat then it is called the "downstream" sensor. Diagram Here.
Probably means a P1157 or P1158 code, both of which refer to that particular sensor.
More on DTC's here: OBD-II Codes & Possible Causes
96halfton
11-06-2016 04:31 PM
LEDERHOS
03-13-2002 02:13 PM
