AC plenum door defrost
Old Sep 8, 2016 | 12:45 PM
jmcgee's Avatar
jmcgee
So, as soon as I got the blower motor fixed, the heater core sprung a leak, so replaced that and onto next gremlin.
Since I have owned the truck (10 years?) the defrost vents have never worked. I do have vacuum, as I can see all the motors moving when I move selector. When I had the heater core out I could see one door moving correctly, but the door that does defrost is further up.
How do I access that door?
I think I am going to have to open it up to find problem. I'm guessing hinge broke.
I read through this,
https://www.ford-trucks.com/forums/1...-problems.html
but still unclear. I can even see how to access that door without pulling dash first.
This is on a 1980 F150 with factory air.
Old Sep 9, 2016 | 10:37 AM
FuzzFace2's Avatar
FuzzFace2
I have an 81 w/factory ac and dash is out but ac/heat box is installed so let me see if I can figure out how to get to it and get back to you.
Dave - - - -
Old Sep 9, 2016 | 01:17 PM
Hound Dog Lew's Avatar
Hound Dog Lew
In my '83 I can see the door you speak of by pulling the glove box. Mine is broken also. I manually switch it to vent for A/C in the summer and back to heat/defrost in winter.
Old Sep 9, 2016 | 06:27 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
18A478 is the defroster door.
Old Sep 9, 2016 | 10:33 PM
jmcgee's Avatar
jmcgee
Thanks everyone. Dummy me, I have factory manual, and read it after I asked question. It clearly says I need to pull steering wheel, drop steering column, remove instrument panel to access plenum where that door is.
But if anyone has first hand knowledge of any shortcuts I would appreciate. Will probably take a day or two off from work to accomplish this one in any reasonable amount of time of the truck out of commission.
Old Sep 11, 2016 | 11:16 AM
FuzzFace2's Avatar
FuzzFace2
jmcgee, looking over pictures I have of the box out of the truck
down a little on the page
https://www.ford-trucks.com/forums/1...re-side-9.html
you can click on pictures for larger ones
1981 Ford F100
1980 Ford F100
I don't see a way to get to the door with out removing the dash & the box from the truck.
Because the box is 2 parts with the fire wall between them I think you can just remove the inside part to fix the door and put it back together and not have to deal with the AC side.
The other poster saying he can get to the door thru glove box sounds like the doors motor is not working where it sounds like your motor is working.
Good luck on the fix and let us know how you make out.
Dave ----
blackwaterairsoft
May 25, 2011 11:19 PM
hrdfrntr95
Jun 5, 2010 10:37 AM
stanz
May 30, 2004 09:55 PM
Charlie Foster
Sep 23, 2003 12:58 PM
Ktown65
Jul 19, 2003 01:46 AM
