Boost PSI?????
Old Nov 8, 2009 | 12:08 PM
  #31
Dave Sponaugle's Avatar
Dave Sponaugle
The few Banks kits I have seen here had a port tapped right into the turbo outlet flange or a bung welded to the downpipe right below the turbo outlet.
I think I remember seeing a plug in the flange the turbo bolts to as well, but never saw one with a thermocouple mounted there.
For some reason ATS kits are much more common here.
I don't think I have ever even seen a Hypermax turbo in person.
Kinda funny how things like that seem to be so regional in their distribution.
Old Nov 8, 2009 | 03:26 PM
  #32
tjc transport's Avatar
tjc transport
i ain't rite
if they have a thermocouple in the outlet side, it was put in by the owner.
banks puts their ports on the inlet side about 4 inches below the turbo on every one i ever seen
Old Nov 8, 2009 | 07:49 PM
  #33
JBoe's Avatar
JBoe
I'll have to check it out to be sure... never really looked. It definately is a long hill. Thanks to the Gear Venders unit it makes the truck pull up it without much problems. The temp definately was right there, locked, around 950-1000. Never really saw any change in oil temps at all. Boost and egts maxed out even if i was out of overdrive and pulling at 3k rpm rather than around 2.5k rpm while in overdrive. (I tested both to see)
It really is a steep long hill so it was great to test on. I'll let you know about the probe's location. Good thing you mentioned it.
Thanks,
Boe
Old Nov 8, 2009 | 10:06 PM
  #34
dyoung14's Avatar
dyoung14
For egts if your using the banks gauge in the factory banks spot then do what banks says to do
Superduty450
6.4L Power Stroke Diesel
13
May 29, 2014 10:02 PM
WesternStar
18
Apr 26, 2011 12:23 AM
86tank
18
Jan 25, 2011 07:26 PM
paintball_pro
34
Nov 5, 2007 02:02 PM
dieselstroke
15
Feb 26, 2005 09:26 PM
