What size carb
Old Aug 20, 2003 | 08:32 PM
go_spider's Avatar
go_spider
Question What size carb
I have a 78 Bronco (work in progress). I am having some trouble finding the right carb to use.
I have a 460 (board 30 over) Miling rv came (light pull). I have had a 600 and a 750 holley on it so far but not satisfied. (it bogs to much) any thoughts?
Old Aug 20, 2003 | 10:01 PM
serving_time's Avatar
serving_time
What size carb
First of all, I think that the 460 site might be the place for this one. Most people here are used to dealing with 300ci's and 1bbl carbs.
That said, if your 600 was bogging, there is a problem with the setup of the carb. The 460 will run on bigger, but a smaller carb is less likely to bog and easier so set up to your engine. Go with the 600 and adjust the thing till you get it running right.
Old Aug 20, 2003 | 10:52 PM
go_spider's Avatar
go_spider
Unhappy What size carb
This was my first time posting and I guess I did it wrong(I saw it after it was posted and tried to change it but it would not let me)
but thanks for the in-put (on the carb thing that is)
Old Aug 20, 2003 | 11:58 PM
broncr's Avatar
broncr
What size carb
When I grow up, I want to put a 460 in my "lil mule" - last night I questioned why someone would ask how to ID a 351 "C" vs "M" - on another "big six" website. Today it dawned on me that every possible way I know of had been listed by other members. The question had been moved - put before the 240/300 - 6 enthusiasts, yet they collectively knew several answers.
The Holley chart says the optimum cfm for a 450(closest ci listed) is 520 CFM @ 5,000 rpm, 580 @ 5,500, 625 @ 6000, 700 @ 6500. How high do you intend to wind it, or where will you be doing MOST of your driving. The 600 probably just needs a bit of tuning (like ST said...) Check with the Big Block Boys...
460powa
20
Dec 24, 2010 05:49 AM
KRDiesel
New Mexico Chapter
16
May 20, 2008 10:45 PM
old_man_winter
Sep 21, 2006 04:35 PM
Jonathon
Oct 17, 2004 10:03 AM
bigeric
Aug 13, 2001 08:51 AM
