cfi to carb
Old Oct 16, 2004 | 10:27 PM
Jonathon's Avatar
Jonathon
cfi to carb
i have a 302 that has cfi. i need to know how to convert it to carb.
thanks,
jonathon
Old Oct 17, 2004 | 08:52 AM
jwtaylor's Avatar
jwtaylor
durapark II distributor or aftermarket
duraspark II coil or aftermarket
duraspark II module or aftermaket
disconnect oem fuel pump and install an electric fuel pump for carbs or possibly use a fuel pressure regulator with the existing fuel pump, your after 6 psi or so
carb
carb intake
That should do it.
Old Oct 17, 2004 | 10:03 AM
51dueller's Avatar
51dueller
I've done this conversion on my '84 Mustang 302. A Ford Motorcraft 2150 will bolt right up to the stock intake manifold. I got some screw in plugs and filled in all the senor and extra vacumn ports. I have Duraspark Ignition from an earlier 302. If you go for aftermarket parts you just need a carb, intake manifold, distributor and coil.
Jonathon
Apr 4, 2012 08:58 PM
Jonathon
Jul 14, 2011 09:17 PM
muscletruck7379
General Automotive Discussion
Jul 17, 2007 06:06 PM
earnhardtracer38
Feb 16, 2006 09:06 PM
2classics
22
Dec 10, 2004 09:24 AM
