E4od problems
Old Sep 4, 2016 | 11:10 PM
Bradmclendon's Avatar
Bradmclendon
E4od problems
Hi guys, new to forum, I have a 1992 f-250 with 5.8L and e4od, I bought this truck in kinda rough shape. The main problem I have is, the overdrive button/switch has been ripped off, the trans does not slip at all and shifts firm, but it will only shift manually, and when manually shift to drive position, it skips 3rd and goes directly to overdrive and lockup . Does it have something to do with ripped out switch . Any help would be greatly appreciated, thanks
Old Sep 5, 2016 | 12:37 AM
Encho's Avatar
Encho
The Southernmost Mod
I really have no idea, you should try getting the codes to see if there is anything there. I don't think the lack of that switch would have such an effect, but I could be wrong. If anything, maybe the solenoid pack could be acting up.
Old Sep 5, 2016 | 04:32 AM
raystankewitz's Avatar
raystankewitz
I will agree with Encho on this. Pull the codes, see if any of them reference the solenoid pack before you go any further. Your problem could one of several things but the codes will help narrow down the search.
Zapp911
Oct 11, 2022 03:32 PM
fordtowman
Nov 29, 2008 01:53 AM
scott9320
Feb 5, 2005 02:58 PM
JCATC
Apr 8, 2004 07:15 AM
fshoffner
Jan 26, 2000 05:41 PM
