ok now what?
Old Oct 31, 2016 | 09:28 AM
  #61
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Originally Posted by Bombguy2
The truck now only gets about 2 miles down the road before it dies, will not restart. I have to wait along time( presumably for it to cool down) before it will start. ...snip... At any rate the engine get to operating temp then it acts up...
This sounds like the IPR is failing when hot, a known symptom. Next time dump a Big Gulp of ice on the IPR to cool it off. If it starts you have the answer.
Old Oct 31, 2016 | 09:36 AM
  #62
Bombguy2's Avatar
Bombguy2
Ill just make plans to change out the IPR with OEM replacement.
Old Oct 31, 2016 | 09:56 AM
  #63
timmyboy76's Avatar
timmyboy76
Make sure that tin nut is tight on the back of ipr
Old Oct 31, 2016 | 11:38 AM
  #64
Pitcrw6's Avatar
Pitcrw6
That was my next suggestion.
Old Oct 31, 2016 | 12:22 PM
  #65
Bombguy2's Avatar
Bombguy2
Just called the FORD dealer and they want $281.35 for a new one with part number F81Z-9C968-AB but I have found multiple OEM ones on various internet sites for about $150....looks like a 3rd party vendor gets be business this time.
Old Oct 31, 2016 | 12:30 PM
  #66
Pitcrw6's Avatar
Pitcrw6
Riffraffdiesel.Com has a great price on the IPR
Old Oct 31, 2016 | 12:37 PM
  #67
Bombguy2's Avatar
Bombguy2
those guys wanted $184.xx
I found it here for $30.00 cheaper for OEM
Motorcraft CM-5013 Fuel Injection Pressure Regulator 95 - 03 7.3
  #68
Walleye Hunter's Avatar
Walleye Hunter
Stay on top of things and make sure that you get OEM. I once got a steal on a water temp sensor, pic showed the sensor, ford insignia on it and all but when it showed up it was a knock-off and it didn't work. That IPR is one pricey item.
Old Oct 31, 2016 | 01:06 PM
  #69
Bombguy2's Avatar
Bombguy2
Ya I figured that OEM is the only way to run with the 7.3.... my other truck( 2013 F150 w/ V6 eccoboost) might get away with less than OEM on some stuff.
Old Oct 31, 2016 | 08:27 PM
  #70
cangim's Avatar
cangim
maybe already checked, but wiring under loom bit me, then the brass nut fell off, if you haven't checked would highly recommend inspecting wires for IPR
Old Jan 21, 2017 | 05:17 PM
  #71
Bombguy2's Avatar
Bombguy2
UPDATE
Finally got home after being gone for almost 2 months.
I ordered a NEW OEM IPR, ICP and pigtail.
I swapped all three and took it for a 10 mile test run and I am happy to report that I have had ZERO issues.
She got up to temp, was shut off and sit then fired right up.
Final question: using Torque pro app, what are good/ acceptable values that I need to look for whith my Log?
Thanks Bombguy2
Brian Ski 44
22
Jun 10, 2018 01:36 PM
electryc_monk
18
Jan 23, 2018 09:39 PM
freerider15
Nov 26, 2015 07:43 PM
Rabbid
43
Jan 7, 2013 06:10 PM
sami001
42
Jun 5, 2012 09:12 AM
