4wd conversion
Old Sep 8, 2016 | 05:41 PM
Franklin2's Avatar
Franklin2
Originally Posted by Johno.h
So basically if I buy a TTB front axle from a wreckers, that will basically bolt straight into place?
Over here in the states yes, the ttb is a bolt in. I am not sure what setup they used over there. Over here, the 2wd twin I beams have the same mounting points as the 4x4 ttb front axle, so it bolts right in. There is no need to frame swap, the frames are the same, 2wd and 4x4. The rear springs are wider on a 4x4 but using the more narrow 2wd springs presents no problems.
jamesgoodhue
17
Sep 8, 2009 01:25 AM
lovemylariat2007
Dec 23, 2008 01:49 AM
fun_suv
Apr 6, 2007 06:19 AM
bshury
Sep 16, 2005 12:10 PM
tmay
Jan 12, 2005 06:16 AM
