best trans temp sensor location?
Old Sep 15, 2016 | 06:19 PM
justcruzin125's Avatar
justcruzin125
Its probably a 12" x10" cooler. As for the tires. I have 265 75 16. Not much bigger than stock
Old Sep 21, 2016 | 02:14 PM
Rocky Mountain F150's Avatar
Rocky Mountain F150
I've got an Autometer gauge in the E4OD test port as well. Runs about 140-150 around town. Has the factory trans cooler towing package as well. When I pull a 2000lb trailer it's around 180-200 deg.
Old Sep 21, 2016 | 05:03 PM
eagle275's Avatar
eagle275
Where's the best place for a C6 to put a gauge sensor? BTW I also installed a B&M deep capacity tranny pan, it has a hole for a sensor. Is that the best place?
Old Sep 21, 2016 | 08:14 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I think the pan is the worst place you can put the sensor. That will always show you the coolest temperature in the trans. The test port on the side of the trans is the best place, in my opinion.
meierw1
Mar 12, 2012 11:33 AM
UNTAMND
Jan 10, 2012 04:25 PM
madmax99
Sep 13, 2004 08:06 PM
lvstang
Aug 23, 2000 09:48 PM
