Code 67 and 41
Old Jun 23, 2004 | 04:29 PM
paxety's Avatar
paxety
Code 67 and 41
I have a new to me '89 Ranger with a new 2.9 engine. The check engine light comes on after warm-up, at warm idle, the engine surges a bit.
I pulled the KOEO codes and got 67 and 41. I suspect the 67 is related to the air conditioner compressor not working, so I'm not concerned about that one. But according to the Haynes manual, 41 can indicate system lean if it shows up during the engine running test. The book says nothing about code 41 during the KOEO test.
Any suggestions?
john
Old Jun 23, 2004 | 09:05 PM
Ken00's Avatar
Ken00
Welcome to FTE!!!
What you got is probably a continuous code. Check the wiring to the O2, fuel pressure and for exhaust leaks, if all is OK then you'll need to run the pinpoint test to determine the exact cause, let me know if you need a copy.
g_k50
1978 - 1996 Big Bronco
Jul 15, 2010 09:39 PM
MemOrex
80
May 29, 2008 09:04 PM
tmryan362
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Mar 13, 2006 04:20 PM
trentmw
Nov 24, 2004 12:50 AM
bgblktruk
Nov 18, 2002 01:32 PM
