HELP, broke down across town. Intermittent hard/no start now it won't start
My wife has been telling me our '01 E-350 (Econoline) with 7.3 is taking several attempts to start in the mornings, like it's not even trying to fire. It will crank like wild but no fire and then it will fire usually and sometimes run a little rough but no always.
Tonight she called me from across town and it won't start at all, cranks like wild but won't start, chug or anything.
The WTS light is working fine, the truck runs great and idles smooth all other times, just been giving grief when starting in the mornings (warm outside 70 degree plus ambient temp). I haven't had the truck do it to me but she has explained it well enough.
I do get a SES light for overboost when I run it hard (PHP tuned) but it always goes away and hasn't caused any issues. Could this be the ICP acting like this? If so, is it true that I can just unplug it and the truck will start by using default pressure?
Any ideas before I go over there and monkey with this thing?
Thanks!
Thanks!
Three things required to start one of these- RPM, oil, and fuel.
You have RPM.
Is the oil full and of decent cleanliness?
Is the fuel pump working?
If you have a decent scanner, I would recommend checking injector control pressure, and cam/crank sync. You need 500psi to enable injectors.
Unplugging the ICP sensor defaults to 2500psi, enabling injectors. If it still won't start, though, there either is less than 300-350psi oil pressure or a lack of fuel.
You have RPM.
I just threw in my new spare camshaft position sensor and no change.. Laying out here in the rain is so amusing. This thing has me stumped... Not getting any fuel out the exhaust so I'm thinking for whatever for forsaken reason the injectors simply aren't firing. I swapped the IDM relay with another unnecessary one and no change after that either.. Damn!
Gotcha, sorry I was all tangled up in the truck and read your reply wrong. I'll have to wait for daylight to investigate that beast, she's HARD to see on this darn Van.
Noticed something weird when I had the key on and was running the scan tool.. After about a minute of the key being on I hear a couple relays click on and off under the dash then the WTS light cycles a couple of times too... Never seen that on my 7.3's before but who knows??
This sounds stupid but I'm almost wondering if it isn't the GPR... In the heat of the moment I may have dove too far into the no start issue. I have the doghouse off and I can't hear it click on. I'm gonna test it after work today. I would think it would start without it once it was warmed up right?? The engine was warm and it didn't even try to start. Anyone have a warm engine not start with a bad GPR?
