Guess this racket!
Old Sep 1, 2016 | 06:58 PM
man-o-war's Avatar
man-o-war
Guess this racket!
00 F250 338k auto
No error codes or warning lights (Forscan verified)
No smoke out of the exhaust
No oil or coolant leaks
Have banging noise from the motor
When cold truck sounds normal, quiet
When it warms up, the banging becomes audible
You can hear it at idle
You can hear it under acceleration
Frequency increases with RPM
When at speed, and letting off the throttle, noise goes away.....comes back when back on the throttle
Any time during driving when I let off, engine quiets down to normal
To me it sounds like exhaust leak, bur not sure how to check for those?
Help, thanks!
Old Sep 1, 2016 | 07:35 PM
The Brad's Avatar
The Brad
Get a flashlight and look around the manifolds for any signs of soot. I've never heard an exhaust leak described as a "banging" sound.
Old Sep 1, 2016 | 07:46 PM
man-o-war's Avatar
man-o-war
It's like loud clicking, clapping....like extra loud cackle. I have had 20 PSDs and never had one with noise like this
Truck runs great otherwise 19mpg mixed and no other issues
Old Sep 1, 2016 | 08:04 PM
Rikster-7700's Avatar
Rikster-7700
Could it be an injector or two has worked loose? Have you checked the torque on them?
Old Sep 1, 2016 | 08:14 PM
man-o-war's Avatar
man-o-war
I had drivers side valve cover off and all those were tight on both screws.
I have no P127x codes showing
Old Sep 1, 2016 | 09:29 PM
bigreentruck's Avatar
bigreentruck
Banging??
If it was a gas engine, based on quiet when letting off, I'd say (& I know nothing),
to look at the wrist pins on the pistons.
BUT, this is Diesel, only 1-1/2 yrs under my belt.
So, with that in mind, I await all you guys opines on this.
Old Sep 1, 2016 | 09:36 PM
man-o-war's Avatar
man-o-war
I considered wrist pin, or valve rocker, but those would still be spinning at 2000rpm when I let off the throttle at 70mph.....only thing that makes sense is that exhaust back pressure prevents the exhaust leak when you let off the gas
Old Sep 1, 2016 | 11:28 PM
twigsV10's Avatar
twigsV10
I'm not going to say it couldn't be an exhaust leak but wouldn't an exhaust leak that could make a bang/tick cause a boost issue or at least a massive exhaust leak under boost? It would have to be pre-turbo.
I seem to recall a thread recently that the injector hold down bolt/stud wasn't loose but actually bent letting the injector move....
Old Sep 1, 2016 | 11:39 PM
man-o-war's Avatar
man-o-war
Maybe you are onto something.
My max boost is 11psi last time I checked
Old Sep 2, 2016 | 12:58 AM
The Brad's Avatar
The Brad
Is it all stock? Could it be cackle?
Old Sep 2, 2016 | 01:11 AM
man-o-war's Avatar
man-o-war
It's very similar to the video, just a little louder. Like a knock. I'll video it and post in the morning
Old Sep 2, 2016 | 01:12 AM
man-o-war's Avatar
man-o-war
Bone stock (aih and ebp deletes)
Old Sep 2, 2016 | 01:45 AM
The Brad's Avatar
The Brad
Mine used to do it pretty loud when I was low on fuel and getting air in the lines. A hutch mod and an FRX from Riffraff will take care of it.
Old Sep 2, 2016 | 01:53 AM
man-o-war's Avatar
man-o-war
I mostly run near full fuel tank. Know well the noise it makes when getting low and air in the lines. It does sound like that.
I have done hutch before, I'll try it here too...and sending unit is acting up maybe fix that as well while in there.
Old Sep 2, 2016 | 11:36 AM
man-o-war's Avatar
man-o-war
Cold start
