Guess this racket!
Old Sep 8, 2016 | 09:58 PM
  #31
man-o-war's Avatar
man-o-war
Originally Posted by Bonanza35
Great Idea! do this and it will rule out pump being bad if pressure stays the same.
Thanks guys I will try that. I was also thinking maybe FPR is weak or leaking internally on the side of the fuel bowl. Truck has 338k who knows if it's original, probably
Old Sep 9, 2016 | 10:32 AM
  #32
knottyrope's Avatar
knottyrope
buy a new FPR spring
I tried the BB mod on mine and the spring bent making lower pressure
new spring is stiffer and a bit shorter but makes the right pressure
Old Sep 9, 2016 | 10:36 AM
  #33
man-o-war's Avatar
man-o-war
Who sells the spring alone? Tnx
Old Sep 9, 2016 | 10:58 AM
  #34
knottyrope's Avatar
knottyrope
ebay has them for 20
Riff Raff has them in a FPR kit for 60
Old Sep 12, 2016 | 05:17 PM
  #35
man-o-war's Avatar
man-o-war
This is how it acts with brand new fuel pump installed......
Any serious load and gauge bottoms out at or towards 0
I have fpr rebuild kit in the mail, but this looks like restriction or air out of tank.
Thanks guys
Old Sep 12, 2016 | 07:09 PM
  #36
jstihl's Avatar
jstihl
i have been having the same knocking noise. Really interested in what you find out, good luck
Old Sep 12, 2016 | 07:16 PM
  #37
man-o-war's Avatar
man-o-war
I'll post on here what I find out. You can clearly hear the clapping sound in this video.
By the way, fuel pressure gauge is 0-100, with truck idling just over 40. Initial key contact needle bounces between 40 and 60psi.
Old Sep 12, 2016 | 11:56 PM
  #38
DaveP.'s Avatar
DaveP.
Two checks for problems prior to the pump:
Insert a piece of clear vinyl hose prior to the pump. If you see air bubbles.....
Temporarily T a vacuum gauge into the supply prior to the pump. If you see high vacuum readings (it should be pretty much zero, but I've never run this test on a Super Duty, so I'm not sure what a normal indication would be. A few inches of vacuum is probably OK.), or the reading increases with load, there's restriction in the supply.
Old Sep 14, 2016 | 07:15 PM
  #39
man-o-war's Avatar
man-o-war
Thanks.
I installed billet fpr kit with blue spring, from eBay, got 80psi at idle and cruising. Still drops when wot, not as bad but down to 30, it's issue on the tank side
Clapping noise still there
Old Sep 15, 2016 | 01:39 PM
  #40
knottyrope's Avatar
knottyrope
30 isn't good at WOT you have another issue that needs finding
Old Sep 30, 2016 | 03:10 PM
  #41
man-o-war's Avatar
man-o-war
I have been watching Perdels on Forscan and it's 0.0 across the board. I am leaning toward exhaust leak
Old Sep 30, 2016 | 03:20 PM
  #42
knottyrope's Avatar
knottyrope
you need more than 30 PSI at WOT
maybe you have an exhaust leak as well
hook up a leaf blower to ex pipe and hunt for leaks with soapy water
Old Sep 30, 2016 | 03:26 PM
  #43
man-o-war's Avatar
man-o-war
Yes Sir, I will do that and report back. Thank you
ffdemoss
Oct 18, 2011 11:26 AM
jasonch
19
Jun 6, 2011 11:36 AM
WorkhorseF250
Nov 10, 2010 08:56 PM
sls
13
Jan 28, 2007 03:40 PM
