Guess this racket!
Old Sep 2, 2016 | 11:38 AM
Bonanza35's Avatar
Bonanza35
When mine did that it was the #8 injector. You could really hear it inside. To me it sounds injector related. Piston pins are a problem also in these engines but to now I haven't had that problem. Check you exhaust manifolds also.
man-o-war's Avatar
man-o-war
Short drive warmed up
Old Sep 2, 2016 | 11:41 AM
man-o-war's Avatar
man-o-war
#8 LL was throwing code intermittently when cold, I shimmed it back to spec and code is gone.
I have spare injector but it's not Long Lead, it's regular. Can I install it in #8? FullForceDiesel told me they are all the same, but #8 sure looks different with blue connector and LL on the coil.
Old Sep 2, 2016 | 12:07 PM
Otto396's Avatar
Otto396
Should be fine. I have all single shots installed in my superduty. It was only installed to help prevent the cackling sound that was posted about before BUT the sound SHOULD ONLY APPEAR DURING IDLE for it to be cackle related. Or at least that is what I have read and heard everywhere.
Old Sep 2, 2016 | 01:50 PM
Bonanza35's Avatar
Bonanza35
Yes, the earlier trucks all had same injectors. When the valve covers are off, check all your push rods, rockers and springs. I'd turn it over by hand so that when at TDC on each cylinder you can spin @ push rod and push on @ spring. We've had people here in the pass with broken springs, bent push rods, even a cracked rockers. You have to pull the cover off any way and that will eliminate that, if okay. If you still showing code on #8 and have spare, give it a shot for sure. The video sounded different when idling.
Old Sep 2, 2016 | 03:48 PM
knottyrope's Avatar
knottyrope
get a 1-100 PSI tire gauge and see what fuel pressure is at idle and WOT
It does sound like an exhaust leak and or starved injectors. put a leaf blower to tail pipe and get some soapy water in a spray bottle and look for bubbles at all mating surfaces on manifold and up pipes
Old Sep 4, 2016 | 06:00 PM
man-o-war's Avatar
man-o-war
Thanks. Will try that.
Today i.discovered that my fuel line connector on the back of the fuel pump (suction side) is missing that white plastic clip that locks it on there. It was basically being held on by the tension of the rubber fuel line. I suspect it was sucking in air there as truck would move. Fixed it by running straight fuel hose from hard line into pump rear nipple. Truck still has some of the clapping, but has picked up some pep as well. I will drive it tonight see if it clears out the air. Also checked fuel filter, bowl was full of clean diesel and filter was very clean, like new.
I am still only boosting 11ish.
Tuesday I will put on spare injector into #8 and se if that makes a difference.
Old Sep 8, 2016 | 08:19 AM
man-o-war's Avatar
man-o-war
I installed fuel pressure gauge, and get only 48psi at idle, and it drops as soon as I give it throttle.
So, I'll try new fuel pump next and see if it increases and holds pressure
Old Sep 8, 2016 | 12:15 PM
Bonanza35's Avatar
Bonanza35
Without reading back, that is a signs of in tank or pinched line also so look at that if you haven't addressed that.
Old Sep 8, 2016 | 12:50 PM
F250_'s Avatar
F250_
Could also be a crumbled pickup foot with pieces getting lodged into the suction tube.
Old Sep 8, 2016 | 01:10 PM
knottyrope's Avatar
knottyrope
maybe try to put suction and return line into a bucket and test it
Then you can rule out pump or tank/line issue
Old Sep 8, 2016 | 02:15 PM
timmyboy76's Avatar
timmyboy76
Sounded/ran just like mine when I'd forget to flip the d2 switch
Old Sep 8, 2016 | 02:32 PM
  #28
Otto396's Avatar
Otto396
D2? As in a tank selector?
Old Sep 8, 2016 | 02:50 PM
  #29
Bonanza35's Avatar
Bonanza35
Great Idea! do this and it will rule out pump being bad if pressure stays the same.
Old Sep 8, 2016 | 03:14 PM
  #30
timmyboy76's Avatar
timmyboy76
Had an on/off switch for the diesel fuel pump. I used to run wvo, so off went the d2
