Sponsored by: Real Truck
help!!
Old Nov 10, 2010 | 04:07 PM
WorkhorseF250's Avatar
WorkhorseF250
help!!
i have a 2006 F-250 5.4l 3v and im still trying to track down what is causing this rattle or ticking noise. i have recorded i bit of what it sounds like, not sure how to get the sound clip to you guys so you can help me.
the truck has 226000 kms on it so its not new, its running good just the noise is getting to me. its not running rich or lean. that is i think it isn't i don't know how else to check that then the exhaust blue or white or smell of fuel or oil right??
when i am accelerating it has a bit of a ticking noise, it sounds like a wet ticking noise, not really sure, when i let off on the throttle it does the same thing but more of a rattle kinda. any ideas would be great. if anyone has a idea how i can get the sound clip on here or for you guys to listen to let me know i am going to try and get a better clip of it aswell. thanks FTE you guys are the best and i hope i can this tracked down
Old Nov 10, 2010 | 04:22 PM
Fishin76's Avatar
Fishin76
There is a good chance that you are hearing the Cam Phasers, Is it loudest at idle, but only after it warms up, or do you hear it at start up (cold)? Does the sound go away above 1500 rpm?
Old Nov 10, 2010 | 04:36 PM
WorkhorseF250
it makes the noise warm or cold. and if i hold the idle at 1000rpm it rattles pretty good, everything is smooth with the idle, just the noise is concerning me
Old Nov 10, 2010 | 05:25 PM
brd7666's Avatar
brd7666
Did you check you exhaust manifold bolts. They have been known to break. It almost sounds like an exhaust leak. Good luck.
Old Nov 10, 2010 | 08:56 PM
V10ZILLA's Avatar
V10ZILLA
Check the exhaust manifold bolts
lmarkie
1997 - 2003 F150
24
Feb 25, 2016 01:16 PM
9402fordguy
Apr 27, 2011 07:42 PM
gcozmo
2004 - 2008 F150
35
Jan 9, 2010 12:36 AM
dderek
Modular V8 (4.6L, 5.4L)
Jul 9, 2007 01:32 AM
seebeew
Exhaust Systems
Sep 5, 2001 03:36 AM
