93 I6 fuel problem
Old Aug 31, 2016 | 06:00 PM
Milpool's Avatar
Milpool
93 I6 fuel problem
Hi all. It appears I have fuel pouring out of the top of the front gas tank (I only use rear). It happens when operating and shortly after, but once it's been parked for a few minutes, it stops. I have another fuel problem too, with the vapor line that is supposed to carry fuel vapor to the charcoal canister carrying actual liquid fuel. I've posted about that one before, but with no solutions found. I assume they are the same problem, it's just gotten worse. (For the vapor one, I just disconnected the line from the charcoal canister, bypassing the issue and not solving it).
Any ideas what I should look for when I drop the tank(s)? Thanks
Old Aug 31, 2016 | 06:07 PM
F150tx's Avatar
F150tx
Trailering
I had the fuel coming out of the fuel cap. I replaced front pump first and it ran better for a while. Then replaced rear pump and now runs great. No fuel coming out any more. I'm not sure but some have mentioned it being something with the check valve in the fuel pumps. I had 200,000 miles on my truck so figure they need to be replaced anyways.
Old Aug 31, 2016 | 06:09 PM
rla2005's Avatar
rla2005
One of the check valves is bad in the front fuel delivery module. Yes, the front. It's getting filled whenever the rear pump is running.
For reference:
Old Sep 1, 2016 | 01:05 PM
Milpool's Avatar
Milpool
thanks. Should I just replace both check valves?
Old Sep 1, 2016 | 02:25 PM
rla2005's Avatar
rla2005
You cannot get just the check valves. You need a complete fuel delivery module.
Old Sep 3, 2016 | 01:39 PM
Milpool's Avatar
Milpool
OK thanks. I can still buy at autozone/oreilly/etc., right?
Old Sep 3, 2016 | 04:59 PM
Milpool's Avatar
Milpool
Well, I've decided to just delete the front tank. My plan is to cap the front tank evap hose, and cap the two fuel lines. I'm going to either cut the tubing from the hanger assembly and weld them shut so I can connect back to the lines and use the retainer clips, or if Oreillys sells hard line with the bead, buy some 5/16" and 3/8" hard line and weld those shut. That should work, right? TIA
Old Sep 6, 2016 | 07:44 AM
rla2005's Avatar
rla2005
I believe Subford has suggested to cut the ends off a fuel filter. You could crimp them closed then weld or use some other method. Not sure how JB Weld would work.
Old Sep 6, 2016 | 08:37 AM
subford's Avatar
subford
I posted that without checking or thinking.
The fuel filter has the wrong size tubes on the ends for the pressure line at the fuel tank.
They are the same size and would work for the return line at the fuel tank however.
cabloom300
Apr 14, 2019 08:23 AM
MA Berlin
Apr 28, 2016 12:34 PM
ejmaso
1947 and Older Ford Trucks
31
Oct 16, 2012 09:57 AM
capitanjo
20
Nov 24, 2011 03:18 PM
Weaponrider
Dec 22, 2006 04:46 AM
