2002 7.3 Mods?
Old Aug 31, 2016 | 12:13 PM
KamiKonze's Avatar
KamiKonze
2002 7.3 Mods?
Hi guys,
I just recently bought a 2002 F-350, with the legendary 7.3 powerstroke with ONLY 56K MILES!!
Its all stock for now... but i dont know what mods to put on it...
heres what im thinking...
1. DP Tuner (which one should I get?)
2. 5 inch MBRP straight pipe
3. aFe intake
4. 160cc injectors? Should I?
5. I dont think so but bigger turbo? Garrett?
I want a tuner that I can have a bunch of tunes on at once and one that I can hook up to a dial on the dash.
Thanks Guys
Old Aug 31, 2016 | 12:25 PM
IDI-Charlie's Avatar
IDI-Charlie
Before putting a chip on, get some gauges on the truck and make sure it is in 100% working order. Tugly put together a good thread about it here:
https://www.ford-trucks.com/forums/1...his-first.html
I do like my DP-Tuner F6/infinity setup. I currently don't have the time to fully write my experiences as I'm heading back to work off lunch, but am more than happy to share them with you this evening when I get off.
Old Aug 31, 2016 | 01:07 PM
F250_'s Avatar
F250_
Welcome to FTE!!
You should identify your HP goals to begin with, and then work backwards from there to identify the requisite supporting mods for air (turbo, IC, plenums, etc.), fuel (pump, filtration, line size, port fittings, regulated return, etc.), oil (HPOP, head fittings, LPOP, etc.), exhaust (i.e. up pipes, down pipe, exhaust piping, etc.), and tuning.
Back when Pinnacle Exhaust was still in the business, their racing design teams found that it's all about managing exhaust velocity, and if you increase diameter too much you will actually end up with an increase in internal back pressure within the exhaust system. Unless you're going after really high horses (i.e. in excess of something like 500 HP), a 4" system will actually perform much better for you.
Old Aug 31, 2016 | 02:51 PM
KamiKonze's Avatar
KamiKonze
I KNEW I FORGOT SOMETHING! Gauges.... definitely a must
Old Aug 31, 2016 | 02:52 PM
KamiKonze's Avatar
KamiKonze
Originally Posted by F250_
Welcome to FTE!!
Alright. Im not really looking for any big power gains, I just want a really deep throaty sounding diesel and when needed, blow some coal on my friends prius
Old Aug 31, 2016 | 03:39 PM
pirate4x4_camo's Avatar
pirate4x4_camo
the douche nozzle behind the wheel controls that function
Old Aug 31, 2016 | 03:44 PM
knottyrope's Avatar
knottyrope
Prius are saving fuel reserves for us to burn up
Old Aug 31, 2016 | 04:43 PM
KamiKonze's Avatar
KamiKonze
how did I know I was gonna get a little backlash for saying that :-|
Old Aug 31, 2016 | 04:55 PM
brian42's Avatar
brian42
Veteran: Navy
Anything over 4" on the exhaust is just appearance. It breathes more than enough with 4" even with go-fast parts. I have MBRP's 4" T-409 turbo-back and I'll tell you that I have no idea how you fit 5" in there. My downpipe b-a-r-e-l-y fits (luckily I already had the turbo out and the up-pipes off when I dropped in the new downpipe...Sous wasn't so lucky). I've had to make a couple of adjustments as it is within about 1/16" of rubbing on my transmission return line (it does rub on the plastic transmission shield). You can get a 75" tip if you feel the need to compensate (mine is a 5" tip) but 4" pipe should do you just fine.
Old Aug 31, 2016 | 05:30 PM
Stewart_H's Avatar
Stewart_H
... and when needed, blow some coal on my friends prius
This isn't a few years ago, so please don't do that.
Because without negative feedback, how else would we let people know rolling coal is no longer acceptable behavior?
Rolling coal helped get the EPA and CARB involved in the diesel enthusiast world. That's not a good thing.
Stewart
Old Aug 31, 2016 | 07:00 PM
Justin@DP-Tuner's Avatar
Justin@DP-Tuner
PREMIUM SPONSOR
Hi guys,
3. aFe intake
Thanks Guys
If you are wanting to have switch-on-the-fly, you will want to run one of our chips (either F5 or F6). Both of them can have a switch mounted on the dash for you to toggle between tunes with. Check the F5 out HERE, and the F6 out HERE.
The rest of your mods sound good, and you can actually find that stuff on our site too.
I would hold off on the larger injectors and turbo for now, and invest in a set of gauges. If you are not satisfied with the power the tuner, intake, and exhaust gives you, then look into larger injectors. Or wait until your stock injectors are worn out, then upgrade when replacing.
Let me know if you have any questions. Would be happy to help you out.
__________________
Justin
Like us on Facebook!
www.dp-tuner.com
Old Aug 31, 2016 | 07:21 PM
bigb56's Avatar
bigb56
Only 56K? Probably a nice rig. No way would I throw a bunch of performance parts on it and start hot rodding it, but that's just me.
Old Aug 31, 2016 | 07:27 PM
knottyrope's Avatar
knottyrope
Guages
Down pipe 3 in to 4 in out
Make sure no CAC or exhaust leaks.
Once running 100% then think of tuner.
Once happy with tuner performance you can upgrade injectors and turbo.
Too many upgrades at once and you may introduce too many variables to trouble shoot performance issues.
Old Sep 1, 2016 | 09:46 AM
HKusp's Avatar
HKusp
Oh I would and that's just me....
Old Sep 1, 2016 | 02:56 PM
Justin@DP-Tuner
PREMIUM SPONSOR
Same here
Never too early to start modding these trucks. But I guess that thinking is how we all got to these forums in the first place.
After all, they are a slug in bone stock form.
__________________
Justin
www.dp-tuner.com
rstrong
16
Dec 11, 2010 09:29 AM
jamesbaughman333
15
Dec 1, 2010 01:29 PM
Quick444
Feb 16, 2009 08:30 PM
01redcrew
20
Jan 8, 2007 07:53 PM
Pablo69
Oct 17, 2004 08:29 PM
