ABS light
Old Aug 30, 2016 | 07:18 AM
PSU4ME's Avatar
PSU4ME
ABS light
My ABS light is on and we just replaced the proportioning valve - no difference. Anyone have experience trouble shooting what could be wrong? The light is annoying so I can always remove the bulb but id like to try and fix the issue. I don't see any sensors at the wheel at all.
Thanks
Old Aug 30, 2016 | 08:53 AM
farmert's Avatar
farmert
Start with the simple things. Check fuse #15 in the in cab fuse panel. If that fuse is blown, the abs light will be on. The wires from the rear speed sensor can make the light burn also.
Old Aug 30, 2016 | 09:19 AM
MoBill122's Avatar
MoBill122
Papa Smurf
The rear axle ABS is known to go bad, and is located on top of gear case. Check all wiring, as a short will turn the light on.
Going to assume you have front disc brakes as my old 95 did, so you should have ABS on both wheel bearings. The ABS sensor in on top of wheel bearing assembly, very hard to see with wheel on... even the brake rotor hides it pretty good. Check the wiring, especially if you go offroading in the truck.
If the ABS light comes on while driving... say after a hard right or left turn, then check your bearing assembly for play.
Several utube videos out there to look at.
Good Luck !
Old Aug 30, 2016 | 10:32 AM
farmert's Avatar
farmert
I have never seen front ABS sensors on the OBS trucks, I don't believe they ever had them.
Old Aug 30, 2016 | 01:22 PM
MoBill122's Avatar
MoBill122
Papa Smurf
Yea, you're right... just the one on the rear end. Just was thinking since my old 95 dually had front disc it had ABS....
I'm old... can't remember that far back...
Old Aug 30, 2016 | 01:53 PM
madpogue's Avatar
madpogue
Does the speedometer work properly?
Old Aug 30, 2016 | 04:50 PM
PSU4ME's Avatar
PSU4ME
Yeah I believe it does
Old Aug 30, 2016 | 06:43 PM
krifenbu's Avatar
krifenbu
This is from the workshop manual and the diagnostic connector is located under the glove box.
Diagnostic Trouble Codes, Retrieving
CAUTION: Care must be taken to connect only the black/orange stripe wire to ground. Connecting the red mating connector wire to ground will result in a blown fuse.
Verify the key is in the RUN position (engine does not need to be running). Next, locate the black RABS II diagnostic connector. The diagnostic connector has two mating halves (one of which has a black/orange wire connected to it). Disconnect the two halves.
Attach one end of a jumper wire to the black with orange stripe wire side of the diagnostic connector. Momentarily ground the other end of the jumper wire by connecting it to a good chassis ground for 1-2 seconds. Grounding this wire should start the yellow REAR ABS warning light flashing. If grounding this wire does not start the yellow REAR ABS warning light flashing, go to the Symptom Chart.
The code consists of a number of short flashes and ends with a long flash. Count the short flashes and include the following long flash in the count to obtain the code number. For example, three short flashes followed by one long flash indicates diagnostic trouble Code 4. The code will continue to repeat itself until the key is turned off. It is recommended that the code be verified by reading it several times. This code will be used later for system repair instructions. It should be written down for future use. Diagnostic trouble code 16 indicates that the anti-lock electronic control module detects normal system operation.
1996 Bronco/F-Series Workshop Manual
Kevin
Old Aug 30, 2016 | 07:25 PM
ReBilld's Avatar
ReBilld
Kevin
Good info Kevin
When you click on the link Kevin posted go to section 06: Brake System and click on it. Then go to section 06-09A: Brake System, Anti-Lock, Rear and click on that. Go down to Symptom Chart--Rear Brake Anti-Lock Control and click that. That gives you all the codes for the ABS and pinpoint tests for each code.
I have fought with my ABS for a while now. Swapped out the valve on the frame with ones from two other trucks, and swapped out the module behind the glove box with ones from three other trucks. The code I was getting each time took me through a trouble shooting procedure that ended up saying to change the module each time. Each time I changed the module, the light went off and stayed off for a while, but would come back on with the same code. I have checked all the wiring, but I think something is killing my modules. I'm tired of chasing it, so I am doing away with the ABS on my truck all together. I'm gonna bypass the valve on the frame and just unplug the module behind the glove box.
Old Aug 31, 2016 | 05:36 PM
mcali2's Avatar
mcali2
I'm about to give up on fixing that code/ light. I have not replaced the wheel speed sensor as it is working but that is all that is left. I cant find the short if there is one.
Old Sep 1, 2016 | 11:25 AM
79jasper's Avatar
79jasper
When op made a thread about buying a replacement RABS valve, I wondered what made him think his was bad. No answer. And most likely no diagnostics.
Need to pull the codes and do the pinpoint tests....
Old Sep 1, 2016 | 11:44 AM
PSU4ME's Avatar
PSU4ME
The valve was completely corroded and it was a proactive replacement. Was hoping it would correct the dash light as well but it didn't.
Old Sep 1, 2016 | 12:45 PM
79jasper's Avatar
79jasper
It's also totally possible that the computer could be bad.
That's why you need to pull the codes.
Justin89
16
Apr 6, 2012 10:52 PM
GALAZIO
Apr 24, 2007 08:38 PM
edub32
53
Feb 5, 2006 09:05 AM
MAD KAO
Sep 23, 2004 10:41 PM
