Hey thanks a lot I've also been trying to find my rear end gear ratio it's a ford 9 inch if anybody has a clue as to where it would be on the rear diff ohh and the motor is no longer a m it has a 351w out of a old e series
There's an outside chance the tag is still on the differential. If it's still there, it should be on one of the studs at about the 2:00 O'clock position.
If it's the original rear, the warranty plate will also give you that info (assuming the door hasn't been swapped). Look on the driver's rear door edge, just below the latch. There's a metal plate attached to the door with two rivets. Look at the "axle" code. Post it and I can decode it for you.
