Take a look at these drums would ya? (Pics)
I've been hearing quite a bit of noise coming out of the front passenger drum so I decided to pop her look today and check out my first drum. It was magical..... Lol. Not really. Was a PITA to get off. PO certainly had her greased up nicley though. The drum was super snug in place with he pressure of the plates push. Maybe designed that way.?.? Anyway. Saw a couple things needing to be replaced here soon. Figured I should go ahead and buy some new spring kits. Cylinders look ok. Not leaky... Responded well to pump test. The adjuster thing at the bottom seemed loose. How tight should that be by the way. No maintenance manual yet so I am just guessing. Anyway. Whatcha think? See any reason they'd be squeakng without my applied foot pressure?
My .02.
Since the drums were tough to get off, then likely they are worn and the shoes are riding in a pocket(run your finger over the surface in the drum and see if it is flat). Could be something rubbing causing the squeak.
That adjuster will be loose with the drums off. Put the drum on the spindle and tighten the spindle nut correctly, then using a screwdriver through that small hole in the back(there is a rubber plug) you rotate that star wheel til there is a light drag on the drum as you rotate it with your hand.
Before assembling, note which way the star wheel has to be turned to tighten(expand) the brakes. It is usually easier to screw the wheel IN to allow easier assembly of the drum/spindle. Then adjust back out.
Looks like the brakes are about 1/2 worn? Kinda hard to see exactly. You can see the taper in the lining material as it goes towards the bottom. The hardware all looks okay.
My .02.
Good catch
Thanks.
If it were me I'd buy spring kits and new wheel cylinders. The wheel cylinders of a name brand. Example...Wagner. 1st because of horsing around with the shoes you've disturbed them. 2nd because over the years crud settles in them. And the piston cups are trying to seal the brake fluid and that crud inside. By disturbing them you may create a leaky wheel cylinder. Rock Auto has this stuff cheap. And please make sure you get a new guide for that self adjuster cable. It's looks makes me nervous.
Didn't have the time to swap anything out. I'm still hearing a rubbing noise. It's a cylindrical noise so I know nothing is stuck. Just each time the rotation hits that spot I hear contact. The exact same noise as before I took it apart. Thinking maybe it's not adjusted correctly or the cylinder is in fact not working properly under load. The other three have no signs or sounds of distress.
ooooohhhhhh. wish I had a maintenance manual.. haynes, etc... whathaveyou. gonna have to locate a picture of one that is correct for reference. this is how the PO had it, but if this ones wrong I need to crack open all 4
on
I'm Jeff replace all hardware.
The rubber end caps on the wheel cylinder is basally a dust boots, to check the inner cups for leakage roll back the dust boots on both ends and take note! look for wet fluids that has leaked pass the inner cups.
Or a yellowish buildup of crusty crud that can cause the one side of the piston to freeze in place. If this happens one side will only be working that may cause the other shoe to drag and not retract to it's normal resting place..
Orich
Orich
ULTRA YOU ARE MY HERO awesome diagram....
Also can anyone explain "self adjusting" vs what I have? worth it?
CLICK HERE
CLICK HERE
