Stickergate / Rear GAWR on SRW 350 is only 6340#???
#256
#259
I am still hoping someone in the know will jump in and explain the process by which "Maximum" is obtained. It is reminiscent of the 2 leaf or 3 leaf springs which had no correlation to the options on the truck and went unexplained as the thread passed away. The dealers, in fact, had no idea there even were the different configurations.
#260
#261
Well I am happy with the new payload chart. The F350 SRW SC 4wd jumped from 3900 pounds to 4710 pound payload. WHOOOOO PEE. We own payload. LOL
2017 Super Duty Truck | Payload Package Selector | Ford.com
#264
#266
on
You know, I'm reading the stickers differently for the first time. Each axle has its own rating but it's very specific to the tires installed and the pressure they're inflated to. The sticker says REAR GAWR = 6340 LBS WITH the 20 inch tires AT 65 PSI cold. It's a formula.
Sticker misprints aside, it stands to reason that a conversation with a state trooper could point out that if better tires are installed on the truck, its capability increases. If a person has the actual axle ratings documented in the glove box and could show that to said trooper, it would be a compelling argument at the side of the road. The sticker is printed to show maximum values when the OEM tires are installed. If the tires change, the overall GAWR changes proportionately.
#267
#268
So what we do know is this:
F250 with 20" has 6340 capacity and tires inflated to 65psi
F350 with 20" has 6340 capacity and tires inflated to 80psi
F350 axle we know has max capacity of 7230
Michelin LTX A/T2 in 275/65R20-E has a max load capacity of 3750 per tire @80psi meaning the tires are good for 7500lbs.
Water fountain at KTP sticker office is hooked to direct feed line from the Jim Beam plant in Clermont, KY.
Guess it's starting to make more sense now.
#269
on
I noticed earlier that the F250 tires were inflation rated at a lower TPI level. That should have to do with the decreased weight ratings and not requiring full inflation and hence give a smoother riding vehicle. I am not sure a discussion about changed tires or inflation would have much influence on the majority of enforcement officers.
#270
