Hello everyone, I was just wondering if anyone had ever deleted to idler steering box and run the steering arm from the right box to the left knuckle. It is an Australian delivered 2004 7.3l F250 super duty. I need to remove it to make room for new brackets and so on. Thanks heaps
Hey buddy, yeah she is like a host town hahaha. So I would like to get rid of the L/H Drive steering box. Okay so the full story is a bought a wrecked f250 and now I'm putting a HJ47 landcruiser body on it. Now to get everything to line up again I had to move the axle forward 100mm in doing this the panhard rod mounts don't line up and I have clearance issues in the engine cross member...... So I need to delete that box to make a new mount and mod the crossmember. Yes it is a massive can of worms lol.
there is a mob down in Melb. that supplies a kit to run straight from the drivers side steering box. New drag link, panhard bar and bracket that fits on the front diff. Nkelly is running it. Send him a PM
Thanks for that. Benefit? Maybe take some slack out of the steering overall?
Mine is a bit of a bus, although the mob I bought it off (Ford) are fitting a new draglink and Ford hubs this week so hopefully tightens it up a bit.
Okay sweet cheers for the info. Yeah it needs to be moved so I use the space where that second box is to make a new panhard rod mount. I need to make a new mount as I have moved the front axle 100mm forward.
Cheers Wayne
it would most probably be the steering box not the dumby box. They could do with a rebuild. check out Blue's thread
Cheers Jason
this kit changes the panhard bar to the other side. As I said it mounts of the front diff and is fixed to the frame under the drivers side
